The audio sources has spiked my curiosity.
I'm not sure why you would wish to hide sources even if you don't often use them? I can understand the usefulness of excluding results from search though e.g. caraoke.
The text at the top of the modal says "Select up to 7 sources to enable" yet there are only 7 available. I wonder therefore if this change is in preparation for more sources to be added, where there's a constraint on the amount of space in the music area to display them therefore you would pick the 7 sources that you most use?
