[UK] 2021.4.x
Discussion in 'The UK and Ireland' started by Medved_77, Jan 31, 2021.
  1. Dilly
    Dilly Active Member
    Norfolk
    I haven’t tried that. I’ll give it a go
  2. Dilly
    Dilly Active Member
    Norfolk
    Just tried it. It was close but no cigar. At a guess it’s about a quarter of mile short.
  3. Zakalwe
    Zakalwe Member
    UK
    Installed 4.11 this morning.
    The good news: it now offers to save adjusted seat profiles.
    The bad news: the car is throwing up Parking Assist errors and the front and rear sensors aren't working. It's been rebooted as well.
    FFS Tesla, get a bloody grip!
  4. AnthonyLR
    AnthonyLR Member
    London
    I was having trouble sending a destination to my car from my phone. Would be happy if this sorted it. Hardly driving due to lockdown...
  5. AnthonyLR
    AnthonyLR Member
    London
    Tesla giveth, and Tesla taketh away
    • Funny x 3
  6. Dilly
    Dilly Active Member
    Norfolk
    This was reported elsewhere. I’ve done some checks and it’s working for me. Dropped pins in Google maps are hit and miss though
  7. Zakalwe
    Zakalwe Member
    UK
    Another error- the car is reporting "Charge port may not open when pressed. Please use another method of opening". I tried it and it seemed to open with a press.
  8. Rustybkts
    Rustybkts Member
    Leicestershire
    Not exactly linked to the update but last week I had no cameras working including reversing, no visualisation (obviously), only speed with no limit icons and a warning that Ecall (emergency services connection) wasn't working. Back to just a car basically!
    Re-boot didn't work.
    Booked a Ranger visit on the App two weeks away.
    The next day I used the car again but re-booted it first. It took a few seconds during driving but all came back as normal.
    A day later got a text saying that the mothership will take a look online and that it may already be ok so I guess they could have already sorted it.
    I have left the Ranger visit booked for now just in case it is a module failing but will cancel if it holds up.
    All very odd but at least this time Tesla have giveth! :)
  9. Gatsojon
    Gatsojon Member
    Manchester UK
    Ok this works.wow. Thank you.
    How on earth does it work? And what is Runscape?
  10. Gatsojon
    Gatsojon Member
    Manchester UK
    Exactly the same for me. All seems fine with this one and the hold park moved up. I'm still not entirely happy with the wider mimic area but at least I don't seem to have inherited the bugs of previous versions of this 2021.04.
    I guess I should thank all those that went through the pain of them so I didn't have to. Thanks guys!
  11. Drew57
    Drew57 Member
    Chester UK
    It looks like those of you with numerous iterations of 2021.4 must finally have a (more) stable version with .11 as lots of us are finally joining you in 2021 (Happy New Year).
    My update came this morning.
  12. Cardo
    Cardo Member
    Surrey, UK
    Ah, yes, this worked a treat. Used their google logon link to authenticate with google, however once I’d signed into google I then cancelled out of linking to Runescape. The Google logon remained and Youtube now works (despite being a little laggy!).
    Runescape is a game. You don’t need to log all the way into it, just as far as authenticating with Google.
  13. Zakalwe
    Zakalwe Member
    UK
    The SC pushed the full firmware at the car (as opposed to the incremental that the car supposedly downloads). This has solved the problem of the parking sensors not working. Yay!
  14. Drew57
    Drew57 Member
    Chester UK
    I like to have the trip card on screen when driving. Last years UI change made it hard to swipe right without spinning the car visualisation around but I found that leaving the finger near the bottom LH corner for a second or so before drawing across did (mostly) work but only safe to do whilst stationary. This was a backward step.
    Then, on 2020.48.35.5 I was pleased to see that the trip card remained on screen, often for days on end without needing to pull it across when setting out on another journey. As I had been stuck on 35.5 for weeks this seemed like real progress.
    However I've done two brief drives today for the first time on 2021.4.11 and it's no longer there when I select Drive. Even more frustrating is a return to the spinning car image until the card eventually draw across. Really annoying.
  15. bhav
    bhav Member
    London, UK
    I think this is more to do with the naff way that Tesla maps works rather than the sharing from phone itself.
    For me, it works best to use a street address (whether directly on the screen or sharing from phone) vs. a postcode. When doing the latter it very often puts me in a random location, I think because it often ignores the second half of the postcode and entirely ignores the street address itself. And often the first half of a postcode is a very long street or wide area.
    If you use street address (e.g. 64 Long Drive or whatever) it typically takes you to precise location.
    So I've just got into the habit of making sure, when I'm sharing from phone, that the pin is picking up an actual street address - works pretty well overall.
    (I'm wondering if root cause is that the car is expecting a zip code, which is usually 5 consecutive digits(?), and not a postcode with a mix of letters, numbers and a space. Feels like something very basic to fix if it is that...)
  16. AndrewGR
    AndrewGR Member
    Oxfordshire, UK
    Maybe it worked like that for me on 35.5 between trips - not sure - but it definitely disappeared if washing the screen or issuing a voice command. Really annoying. Voice command “odometer window” seemed reasonably reliable to get it back with whatever trip screen I had before. Just ‘upgraded’ to 2021.4.11 so waiting to see what new delights await! Moving the brake hold indication back somewhere visible sounds like the sole improvement but hopefully means they have recognised the importance of making warning lights visible and the old UI or something like it will reappear soon.
  17. Medved_77
    Medved_77 TM3 SR+ | MSM+Black | No FSD
    Scotland
    First drive with 2021.4.11 today, didn't come across any new defects but did notice a big improvement in voice controls, particularly when finding music on spotify. Each press heard my request, parsed it correctly then found the correct artist/song. Was really quite enjoyable.
  18. Dilly
    Dilly Active Member
    Norfolk
    I agree, though for the wrong reason. I was trying my best to persuade a search of my USB music. Every attempt failed but it did find every request on Spotify! I came to the conclusion that since most if not all my music is on Spotify, I’m not really bothered with having it on USB.
    My music plays fine but I have to find it manually.
  19. Phill G
    Phill G Member
    West Midlands UK
    what were / are you using to send destinations to your car
  20. Cloggie
    Cloggie Member
    West Midlands, UK
    My car upgraded to 4.11 yesterday. Not sure if it is related, but I had very low regen on 4.6 and it is much stronger on 4.11.
    Still 3 degrees outside, not much different from the last few days. The difference is noticeable, on 4.6 I needed to use the brakes for the first 10 minutes and this mornign the car only had 3 or 4 dots and strong regen was available straight away.
    Has anyone else had this?
