you can buy hockey pucks and use those on normal jack stands if you google it there are special adaptors you can buy off ebay that slot into the holes in the sills, this is a better option and more secure so you don't damage the battery
So buy pucks or the adaptors and any garage should be ok to use them?
cool thanks all - seems like there are loads of 'jack pads' on eBay for the Model S so will probably just buy a pair of those!
is this in the service screen? and same on M3?
I bought one from Ali Express then decided I should probably have 4, so bought 3 more on Ebay. All 4 seem identical to me. Here is the link to the Ebay ones: For Tesla Model 3 Chassis Specific Jack Pad Tool Car Jack Lift Pad Adapter L&6 | eBayMore specifically are there any that people can recommend as many reviews on Amazon say they are basically rubbish and fall apart?
Check with your local garage. I turned up in my M3 with pucks in hand but their jacks are already padded.
I heard negative reports on the all plastic/composite ones. The ones I bought are metal with a rubber pad on the top. I have only used them once when swapping my summer for winter wheels, and they fit and worked fine. If I were buying again now, I might opt for the set from Abstract Ocean, which also come in a storage tube. Otherwise I would certainly be happy to get the ones I have.
I got these from the U.S. Ordered Tuesday, delivered Friday. Highly recommended elsewhere on this forum.More specifically are there any that people can recommend as many reviews on Amazon say they are basically rubbish and fall apart?
The one I purchased from Ali Express seems identical to the eBay ones I posted the link to, and cost US$20.01 with shipping.thanks but at £12 each might look at the Ali express ones
