[UK] Holiday update - 2020.48.26/.30/.35.x
Discussion in 'The UK and Ireland' started by VanillaAir_UK, Dec 19, 2020.
Thread Status:
The first post in this thread is a WikiPost, and can be edited by anyone with the appropriate permissions.
  1. Dilly
    Dilly Active Member
    Norfolk
    Somewhere in the bowels of my loft, is my 1970’s set of Maserati air horns.
    They did a fair job of warning pedestrians of my approach. :p
    I wonder if they still work...
    The downside was that the compressor drew more power than main beam!
  2. Tony Hoyle
    Tony Hoyle Member
    Stockport, UK
    Even as late as this march people were reporting their cars had the space for a speaker but it wasn't fitted. I haven't heard of anyone with a 2021 update checking yet.. little reason to until now. Of course now they don't have to, if they get the update and no boombox, there's no speaker.
  3. Tony Hoyle
    Tony Hoyle Member
    Stockport, UK
    Elon has said it's not an easy retrofit. https://twitter.com/elonmusk/status/1181738919076851712?s=21
    That means if they do it it won't be cheap..an of course rigging something yourself won't work because the software has to be told it exists as well.
  4. sonix
    sonix Member
    Wales
    Probably easy on cars made post the initial introduction (someone has mentioned that the harness is ready for the speaker).
  5. Anfieldgaz
    Anfieldgaz Member
    Uk
    Well it'd certainly say this update isn't even one "fire"
  6. Acko1985
    Acko1985 Member
    UK
    I thought all the refresh models came from the US factory so surely they wouldn’t spend time not installing it if the cars were going to Europe?
  7. OrangeMikey
    OrangeMikey Member
    London, UK
    Not seen it on one car in Europe (from checking Teslafi and Tesla Scope) yet, so I make that zero fire!
  8. Tony Hoyle
    Tony Hoyle Member
    Stockport, UK
    There are lots of minor differences between EU and US spec.. not putting a speaker and a bit of wire on the BOM is trivial by comparison, and saves them money.
  9. Medved_77
    Medved_77 TM3 SR+ | MSM+Black | No FSD
    Scotland
    #109 Medved_77, Dec 25, 2020
    Refreshed UI is really nice IMO. Nice having the wipers and rear camera buttons permanently available. The wheels and windows moving in the car visualisations are slick, if not functional.
    Being able to time a charge to start/stop during off peak times is useful as well, and removes the need for a separate service to ensure you charge when cheapest.
    I think it's a nice part one.
    • Like x 4
  10. Battpower
    Battpower Supporting Member
    Uk
    Still have my '72 5 horn 'La Cucaracha' ! Sad it can't be used :-( [at least in UK].
  11. Battpower
    Uk
    Agree. Already have my charge outlet on a time switch, but still nice to have built-in scheduler.
  12. GRiLLA
    GRiLLA Member
    UK
    Waste time not installing it? Wut? Anyway it's easy to check, just open up the two tabs at the front of the drivers side front wheel, you'll see the grill in the floor, and a loose cable not connected. At least, that's what my August 2019 M3 LR has, I was surprised to see the wiring was there as the speaker wasn't fitted to the US spec until September 2019, but it is.
    It's all academic anyway, as I shared above the UK has regulations against any novelty horns, which is probably a good thing really. The one thing I'm not clear of is there is a suggestion that there might be an option for the noise to be inside the car, leaving the regular horn outside, that might be permissible. The regulations for the AVAS leave a few more options, but I'll bet that coconuts won't pass. It would clearly confuse blind pedestrians.
    Personally if a retrofit was available in the UK I would take it, even if it's just a perceived safety benefit for pedestrians I would try. Mrs hs a Leaf that voluntarily makes a noise, it's barely audible inside.
  13. Tony Hoyle
    Tony Hoyle Member
    Stockport, UK
    But the external speaker isn't the horn.. as long as that exists the regulations are fulfilled.
    The twizy had an additional pedestrian horn for example.
  14. Bootneckshuffl
    Durham
    Anyone in the U.K. have this then?
    Elon Claus hasn’t been to mine like
  15. CMc1
    CMc1 supercharge.info editor
    North, UK
    No EU cars yet
  16. VanillaAir_UK
    VanillaAir_UK Supporting Member
    Surrey, UK
    #116 VanillaAir_UK, Dec 26, 2020
    • Informative x 3
  17. Mark-R
    Mark-R Member
    Shropshire, UK
    #117 Mark-R, Dec 26, 2020
    Is the external speaker also missing from Teslas in other European countries? The Boombox seems to be the main feature in this update (Elon admits it's only half a 'fire' in a car without a pedestrian speaker), so perhaps the rollout is initially targeting cars/regions with the speaker.
  18. Type2
    Type2 Member
    Liverpool
    “We couldn’t get everything done in time”. That sums Tesla up perfectly :p
  19. Tony Hoyle
    Tony Hoyle Member
    Stockport, UK
    Apparently some later ones have the wiring loom, but I checked mine (August 2019) and there's nothing there.
  20. GRiLLA
    GRiLLA Member
    UK
    I'm August 2019 and I have the wiring for the speaker.
Thread Status:
