Note: This feature currently requires accessing the site using the built-in Safari browser.
50kWh was the guess for the SR model, not SR+.OK, so I've looked at this some more. I am seeing that people think it is a 50kWh battery, so 208 Wh/m gets you to 240 miles range. I've read that 217 is used for EPA calc, which does get me to the 185 range am seeing for 80% charge. Today, I started with 185 miles (80% charge). I've driven 62 miles at 279Wh/m which is 17kWh used. If the battery is 50kWh, that means there is 23kwH capacity left. Divide that by the 217, and I should see a range of 106 miles left. I actually see just 85miles. Everything I have read says the miles remaining on the battery item does NOT take into account how you are actually driving. If it did, the 85 miles would make a bit more sense, as this would seem to assume 270 W/m, which is in line with what I did for the 62 miles. This all seems very complicated, but the bottom line is that they range seems a LONG way short of the 240 EPA and the 256 WLTP advertised- todays 60 miles at 279wh would mean to total range of 180 miles, nowhere near 240. I'm sure I am not the only new owner trying to get there head around this and finding range is way less than expected. HELP!!!
And however carefully I drive, I can't get anywhere close to projected range. Driving home this evening (440ft elevation gain over 19 miles) used an average of 340 wh/miles. Average speed was 22 mph. Close to no wind, and a mild 15degree's. To get the EPA range I think you need to hit 220 wh/miles and I can't imagine how I could come close to achieving that.
Very strange. Your efficiency is terrible. Have you looked at your tires? Are they filled? They aren't wobbling or anything? At 25mph, even with an elevation rise, you should have amazingly good efficiency. Try turning off the heat next time. What's your lifetime efficiency?
