spdpsba
I don’t think he is from Winchester, Massachusetts!Are you based in the UK still waiting for that update the sooner the better
what would be interesting for anyone else posting these sorts of images is if you could get out and take a photo so we can see how the sensor view from the car compares to the actual position relative to the obsticleApologies for dirty screen (I'll blame the wife).. very quick and simple test - it seems to work ok in currently good conditions. Not sure why my brick wall is so wiggly...
Definitely says stop about 10 inches early out from front.. which I guess it better than doing it late.
Will be interesting to see how this works in people with different environments and more importantly, what happens when there's crud all over the reversing camera!
Please post your examples
View attachment 922121View attachment 922122View attachment 922123View attachment 922124
Brilliant, just brilliant. Thanks for the morning chuckle!…kerb detection might be the thing that finally gets me to call off the fatwa I put on the guy who came up with the idea of alloy wheels.
In my experience, that action has unforeseen and generally unpleasant and unwanted consequences. Good luck though.…(I'll blame the wife)…
That's my main gripe, as someone who doesn't have any skin in the game. This release should have been available on or very shortly after cars started being delivered without USS, not 6 months later.Just gave mine a trial on a trip out for lunch! There is good and bad:
Good: Detects kerbs REALLY well, much better than the USS used to.
Bad: Really over-cautious on a low stone wall we have in our drive. Seemed to think its way closer than it was.
I can also confirm its active when driving, I see flashes of it now and then, even when zipping along narrow roads. There may be some speed limit where it deactivates, but if so, its pretty high.
Not as good as USS, and not as smooth a UI for sure, but bodes well for a first release of it. Definitely better than nothing. Still ridiculous it wasn't ready from day 1.
My totally unsubstantiated theory is that it shares some of the same foundational components with the single stack, so it was blocked on FSD 11 stabilising. The fact that we received it shortly after 11.3 started to go wider doesn't prove this is correct but it does fit.Not as good as USS, and not as smooth a UI for sure, but bodes well for a first release of it. Definitely better than nothing. Still ridiculous it wasn't ready from day 1.
198Wh/miles - that’s amazing in this weather. I am on 280-290Wh/miles.The wiggles also seem to appear when driving at low speeds - above 18mph they disappear. Few examples with a still smudgy screen.
I instantly thought of the same!! I get around 280-300 in this weather!198Wh/miles - that’s amazing in this weather. I am on 280-290Wh/miles.
I guess yours is LR.
It might be seeing that charge cable, seems to match the nearest section where it's red.The red lines are the bin store behind the car (which is flat) and a very poor representation of the edging down the side of the drive (as can be seen in the RH camera view & the 3rd picture).
STOP appears at the distance I parked the car & that is OK, albeit about a foot away.
As in the third picture, the car is actually about 8" from the edge of the drive so the area where the red appears to touch the car is completely inaccurate (beyond the front of the car the line is visible in white and this should continue parallel all the way down the side)
The feint white line on the other side of the car is picking up my wife's Fiat which is on the charger and far enough away not to be an issue.
No, that's not correct.It might be seeing that charge cable, seems to match the nearest section where it's red.
That's a bit too sensitive if so. Not great that it's unclear either way.It might be seeing that charge cable, seems to match the nearest section where it's red.
