rfmurphy81
This seems like more of a software issue than anything, as I definitely don't remember this happening before. I'm curious if the Service Center can confirm why and when this changed.
My assumption was that the throbbing green actually reflects the car drawing current for any reason. That could be for charging, but it could be to run climate control too, or various other things. Presumably it's all the same from the point of view of the systems from the wall plug through to the onboard component that converts the AC from the wall to DC for distribution internally (I assume this to be the "charger" even though it's not being used for charging in the example case I chose).Climate control shouldn't control whether or not the car is actively charging, but blue vs. green does indicate standby vs. charging.
[etc]From https://www.tesla.com/sites/default...Manual_Touchscreen_DAS_NA_R20160317_en_US.pdf, page 132:
Charge Port Light
Recently (last few weeks?) I've had the problem that the button on the UMC handle doesn't properly unlock my charge cable. The light cycles a few different colors, briefly (split-second) flashes white for unlocked, but then goes back to the color it started with and re-locks. In this situation I've taken to unlocking the cable by long-hold on the trunk button of the fob, which always works (so far).
Charge Port Light
• WHITE: The charge port door is open and Model S is ready to charge. The connector either hasn't been inserted yet, or the latch is released and the connector is ready to be removed.
• SOLID GREEN: Charging is complete.
• BLINKING GREEN: Charging is in progress. As Model S approaches a full charge, the frequency of the blinking is slower.
• BLUE: Model S detects that a connector has been plugged in, but charging has not started. Either Model S is preparing to charge, or a charging session is scheduled to begin at a specified future time.
• SOLID AMBER: The connector is not fully plugged in. Realign the connector to thecharge port and insert fully.
• BLINKING AMBER: Model S is charging at a reduced current (AC charging only).
• RED: A fault is detected and charging has stopped. Check the instrument panel ortouchscreen for a message describing the fault.
[etc]
Yeah, not precisely right, is it? At least for blinking green since as we just discussed upthread, it seems to mean "pulling current" and not necessarily charging per se (though of course charging is the most important application of pulling current).
Pressing the button does 2 things: It makes the proximity line in the charge port go high, and it transmits a radio signal on 315Mhz do the car.
The proximity signal if restored is that same mode that tells the charger it's OK to start charging, so pressing it only briefly will stop/release but when you let off the button, the proximity line will go back low and it will re-latch.
I have the opposite case with my UMC, the other switch in it failed.
Under the button thing you press are 2 switches side by side that depress and release in unison as you press and release the button.
Mine has the RF switch failing, so it will not pop the door.
But the latch release switch is fine, so I can still pull the handle out.
I am using other methods to pop the door.
The UMC that was delivered with the car is considered by Tesla as car equipment covered by the car warranty. When I purchased the car I also bought a HPWC with it, which was also covered by the car warranty - good thing too because the handle burnt and I got a new unit.
You should get a new UMC from Tesla under warranty.
I don't want a new one, because they have lowered the power delivery of new UMC in Canada to 32A, whereas my older one does 40A. I wish these units had serviceable handles but they don't. I would have to destroy the handle to open it up to get at the switches.
Had no choice but to open the trunk and pull the manual port release cable.
Then everything was happy. Was able to drive.
You might be able to just go to the service center and get the replacement UMC there. They love car count, and it would be easy to check. Just let them know that your other UMC cable works, so all you need is a replacement. Unless, you're out of warranty lol.My UMC went further downhill tonight.
Got charging interrupted notification several hours into the charge.
Walked out, not charging, had to unlock with app.
Cycle UMC power, plug in again. Still nothing.
Press unlock and this time the latch quickly opens then closes. Except the car thinks it is unlatched!
And now I have RED charge light!
Can't unlock port.
Jump in and press brake as Im about to do a reboot. Car goes nuts, two second cycle between moving between driver and easy access profiles, trying to drive, but canceling because it is plugged in, but not plugged in! Something is very sick!
Hard rebooted...lights continued to turn on and off every two seconds.
Had several charge port errors on display. Still count not unlock latch!
Tried plugging back in, but it did not latch at all. Still says disconnected.
Tried cleaning contacts in handle and port with alcohol and q-tip. No help.
Finally gave up and switched to my second UMC, and it's happily charging.
So the next question is how to make Tesla respond to my support request from yesterday...
PS Nothing but green lights on the UMC. Something is strange here. I will definitely be cracking it open if I get a replacement.
