There is nothing wrong with the power at my office.
If there is nothing "wrong" there is at the very least something "different"
Tesla sent an electrician twice and he said it was the car (or UMC).
Exactly what did they say? Do you have any report or documentation from them?
My electrician says it is not the power and if another device is interfering with it then it is the car's fault because everything else is UL approved.
Just because something is UL approved doesn't suddenly make it immune to misbehaving or malfunctioning. Obviously there is something different in your environment and you're going to have to figure out what that is.
The city electrical inspector likely won't even allow me to plug in the car because it isn't UL marked...it's the law! Whoever said that since it is a vehicle it is exempt is mistaken...these are local codes and have not been altered for Tesla's or Nissan's sake. If someone has a copy of the 2014 NEC and can post an excerpt that states that vehicle charging equipment shall be exempt from UL harmonized standards, I would like to see it.
I will turn this back on you and ask you to quote the part of the NEC that says that every device connected to a NEMA14-50 outlet must be listed (their terminology for having a mark from a certified testing lab - not necessarily the UL). I don't think you will find anything like this in the NEC, but I haven't read the whole thing so I may be mistaken. Obviously this is not illegal because Tesla would have been stopped long ago. When my inspector came to inspect my 14-50 outlet, he had similar concerns about lack of listing markings, but after discussing it with Tesla, he passed the inspection, so they must have told him something to help him understand the law.
I have tried 120V charging from outlets in different parts of the building and fed from different panels all with the same result.
What kind of building is this? You mentioned 208 so it must be a commercial 3-phase service. Does the building have 480/277 coming in and then transformers that step that down to 208? Don't know why that would make a difference, but I was curious. What kind of business is this? What kind of equipment is in the building and neighboring businesses?
Charge cable fault is what comes up in the car, and yes Tesla tried three other UMC's. When on the 208 outlet the voltage is around 213 until the failure.
So are you saying that it does charge successfully for some time before failing? If so, how long does it work for before the failure? Would still really like to know what the LED on the UMC looks like when the failure happens.
Absolutely nothing happens on the line side at this moment....no fluctuation other than the one or so volt rise when the car stops charging.
Well, obviously *something* happens because the UMC is not just randomly deciding to not work at this one location. How are you measuring the voltage at the time the problem happens? I'd look to see if something strange is going on with the neutral or ground at the time
Because of the physical panel and outlet layout there is little room to play with line filtering, but I will study that more.
This is good advice and I think you should look into it as well.
If I used a J1772 charging station, wouldn't I still need to plug in the UMC?
No - you will just need the J1772 to Tesla adaptor that came with your car. This is a passive device that just converts one plug to another.
