UMC Vs HP Wall Connector
Discussion in 'Supercharging & Charging Infrastructure' started by NigelM, Apr 7, 2011.
  1. bonnie
    bonnie I play a nice person on twitter.
    Columbia River Gorge
    I have the UMC charger plugged into a NEMA14-50, 240V 50A circuit - no problems. It is slightly warm when charging, but not at a level that would concern me.
  2. cinergi
    cinergi Active Member
    MA
    Mine's plugged in 24x7 outside (I did pull it inside when I expected a lot of snow so I didn't worry about not being able to see the cable while using the snowblower). About 6 months now, no issues.
  3. zack
    zack Member
    Minneapolis, MN
    Mine's plugged in 24/7 as well, no issues at all. What's in that blob is basically an over-sized ground fault interrupter with a detector for the signal coming from the car. The relay coil is probably what's giving off the most heat.
  4. scott451
    scott451 KWH-PWR#1349Sprt,S Sig#96
    Palo Alto
    Actually, it's a GFI extension cord with a "pilot" signal going to the car telling the car the maximum current it can draw.
  5. jaanton
    jaanton Roadster NA #1026
    Oakland, CA
    Putting a meter to the Tesla connector, the UMC will not energize the power pins unless the pilot signal pin has been pulled to ground via the diode and resistor. So information is really going to and from the car at the same time.
  6. scott451
    Palo Alto
    Yes, that's correct. I was describing the most basic implementation of a charger like the one I built here. If you signal the max current to the car and ignore the response from the car, the car will start charging. The reverse is not true.
  7. samcarney
    samcarney Sam C
    Great Lakes, Sonoran Desert
    I have a RFMC plugged into a NEMA 14-50 for the past 2 years. It does not get warm, the only current flow is for the LED's.
