Ummm... My car won't turn on.
svp6
731
771
MN
Make sure that under Controls / Display settings you have power saving to "off" and the "always on" box checked. Otherwise your displays will power off and may take some time to boot.
Driving in Minnesota for 2 winters was not a problem other than a severe drop in range. No issues starting the car at any temperature.
Keep the car plugged every night
Reactions: hiroshiy
SSD420
915
303
ON, Canada
I
I do almost every night but when the car finishes charging, does it really need to stay plugged in?
svp6
731
771
MN
I already charge to 90% so how much extra can I charge? Or do you mean just more pit stops throughout my day to get smaller top up charges?
You don't need to charge during the day unless travelling long distance - just plug in every evening and fill to 90%. On the P85D I can get a 170-180 mile trip in winter time, but that is paying attention to speed and energy usage. At 75 mph with heating on I get close to 450-500 Wh/mi in very cold winter time. I suspect your X may be using a little more energy than that. It also helps to preheat the car in the morning before disconnecting the plug.
TexasEV
7,641
8,469
Austin, TX
You shouldn't need to charge more on a normal day just driving around town unless you do an extreme amount of driving on your normal day. Cold only becomes a practical concern when you're driving long distances, then figure up to 30% reduction in range so plan to stop to charge more often or spend more time at superchargers.
TexasEV
7,641
8,469
Austin, TX
Does that do anything? I thought when it finishes charging it no longer takes any juice, hence the phantom drain...
The mistake I do keep making though is that I should be heating my car while it's still plugged in. Its frigging cold in here! My heated seat is on, but every time it gets really warm it seems to shut off. Yet another question for TMC; is this normal? Or anlther thing to add to my "list" for the SC next week?
Remember, a connected Model S is a happy Model S, and that goes for the Model X too.
A connected Model S is a happy Model S
Reactions: SSD420
SSD420
915
303
ON, Canada
On a "normal day" I do a ton of driving. My car is only about 2 ½ months new. I'm at 12,000+ km. It would probably be much higher if the SC didn't have it for 2 weeks last month.
ggnykk
1,573
737
Earth
I meant that u will have much higher Wh/km (or Wh/mile) energy usage in cold weather. So with the same battery soc, u can reach a shorter distance in winter as opposed to summer time. If you have charging at home and at work, things should be easy in winter.
Jeeps17
Cath Jockey in a P85
Mar 17, 2012
1,013
385
Montreal, Canada
One significant advantage of leaving it plugged in during winter is that you can pre-heat the vehicle before you leave using grid power instead of your batteries.
And as a side bonus, I cannot remember the last time I had to scrape snow or ice off windows in my S, pre-heating does an amazing job of it.
Reactions: SSD420
