Unable to charge with home charger; no light; connector needs cleaning
For the last several months, my home charger intermittently would not be recognized as plug in. The charger port light that would normally turned dark blue after plugin was just not there, nothing, no light. No error light on charger either. It would work again randomly so it was hard to find a pattern, only that it was getting bad more often. I checked the connector and it looked shiny and clean. However, a swab of a q-tip with alcohol came out all black! all terminal pins on the connector were the same. Anyway, after throughly cleaned all large and small pins on the connector as well as on the charge port, charging seems to be consistently good now.
Also, after connector cleaning, the voltage drop during charging is less than before. It used to drop around 5-6 volt at 16-20amp charge. Now it only drops 3-4 volt.
I'm just writing this as an FYI to others. I've had the X car since 2016 and this is the first time I cleaned the home charger connector and port. Should this be a recommended periodic maintenance?
DCGOO
2,646
1,859
Indianapolis, IN
What kind of charger/connector were you using? I've never seen a Tesla connector with a blue light.
Rocky_H
8,365
10,763
Boise, ID
He said the "port" had a blue light, not the charge plug. Blue is one of the normal colors for the light on the car's charge port.
Reactions: DCGOO
