Just got back from the Service Center...(more on that in a sec)
Yesterday, I decided to do a factory restore on my car, as there were a lot of settings I wanted to change from her previous owner as well as wanting a fresh start on all the systems.
So, I initiated the factory restore feature from the Settings and now my center screen is dead. I called Tech Support but they could not connect to the car.
I also tried resetting the car using the two-button reset. It works (my phone, plugged into the dock in the center console acts as if I just plugged it in) but nothing happens on the screen. I also get the message on the instrument cluster "Systems Starting Up..." But it just stays there until I press the brake pedal (clears when I do that after about 20s).
Took her down to the SC this morning (car still drives, just no A/C, music, daytime running lights, etc.) and they weren't able to connect to the car to flash the firmware.
Anyone here might know what happened here, and better yet, what should happen next?
The girl working with the the Service team said that because I initiated the restore from the settings menu, that it wasn't anything that was my fault, but they are checking to see if it's covered under the warranty(!).
Just thought I'd share this with you all and get an idea of what's going on...
