I had appointment today with Tesla Mobile Service to fix non-operational electric door unlatch (manual was opening the door) and charge port door which would not open using a button on mobile connector plug (and couple other even more minor things). While replacing the charge port tech connected the 12V battery to the external charger per the procedure (based on his explanation). He proceeded replacing the charge port without noticing that one of the leads of the charger disconnected, causing 12V to go dead during the firmware update following the installation of the new charge port.
As a result, the 12V is battery dead, and connecting the charger doesn't bring neither the 12V battery nor the aux system to a proper voltage to energize it. So the car is not drivable and requires tow to the service center because mobile techs (the mobile tech working on my car called for reinforcement) could not power the 12V aux system. They say that car needs a tow to replace the 12V battery, but I am concerned that the problem now could be deeper, as I don't understand why connecting the external charger doesn't power the 12V aux system, making the car non-drivable.
Anybody else with a similar problem?
