I experienced the subject issue after parking in a spot that had a slight incline up. I parked over a low curb which had PLENTY of clearance under the front spoiler (which was verified after initially parking).
After an hour, when starting the vehicle to depart, I noticed a vehicle alert indicating it had entered "Jack Mode". The front end suspension had dropped down resulting in the spoiler resting on the curb! Recognizing this was an error potentially likely caused by bad or inaccurate sensor, I accessed the screen in an attempt to disengage the Jack Mode. The vehicle would NOT allow me to deselect it. This forced me to back out of the parking spot with the front spoiler scraping the curb and then suddenly dropping down after clearing the curb.
I then moved the vehicle (it remained in Jack Mode) to another, more level spot away from the curb and parked. This time, I was able to deselect the Jack Mode and the vehicle suspension raised to Standard height. Needless to say, the bottom of the spoiler was badly scraped.
Since the vehicle is less than a month old, I scheduled a service appointment to address the issue (along with a driver's mirror misalignment and software issues related to Easy Entry and random display changing problems). The service center personnel indicated they were aware of other reports regarding spontaneous entry into Jack Mode but that Tesla's position is that the functional design is based on safety (i.e. maintaining level vehicle position) and that it is the driver's responsibility to manually set the suspension to HIGH or VERY HIGH ANYTIME a vehicle is parked over a curb IN ANTICIPATION of the vehicle possibly spontaneously lowering the front suspension causing the front spoiler to rest on a curb. This is blatantly unacceptable as drivers should NOT be required to manually raise the suspension every time they park over a curb.
The service center technician agreed to my request to submit an "internal" firmware change request which will allow the driver to override the Jack Mode under such conditions. I have little confidence that the request will actually be submitted and, even if it is, will be ignored. Since it only occurs when the vehicle is parked, it does not impact safety. It will, however, prevent unnecessary vehicle damage. As with any issue, manufacturers (Tesla) will only take action if a a significant number of owners report the issue. Hopefully, other owners will take the time to submit forum entries if/when a similar issue occurs to them.
