Underbelly Damage?
Discussion in 'Model 3' started by Justinwaters, Jul 12, 2019.
  1. Justinwaters
    Justinwaters Member
    Reno, NV
    Hey y'all! So about a month ago i was driving at midnight at about 40mph on a paved road. There was an object in the road and when i tried to swerve to avoid it, my M3 just didnt have the clearance and the composite got a little scraped up. Being that the car kept driving and no alerts happened, i figured all is good, checked up on the damage in the morning, no fluid leaks or dents visible. One month later i cant drive the car! 12 volt battery failure it says. Tesla tows it to their center and tells me they need 13 grand to get a new battery pack and replace the coolant. In the pictures below you can see the damage from the object i hit about a month ago. You'll notice the battery protector is not punctured. Youll notice that theres a little metal piece putting a little pressure on a coolant hose but there has never been a leak or anything like that. Wondering if ANYONE out there has an explanation for how my battery pack needs replacement when no connection to the 12 volt was damaged? PS battery has held same charge level as pre scrape.
    • [​IMG][​IMG][​IMG][​IMG][​IMG]
  2. TORQU3
    TORQU3 Member
    MA
    I don’t see the pictures.
    Sounds like you might need to make an insurance claim if you hit something.
  3. Wennfred
    Wennfred Member
    San Diego
    How about replacing the 12 volt battery yourself and see if you can continue. The car says 12 volt battery but you see no under damage. Upload the pictures again, we can’t see them.
    Fred
  4. Piwacet
    Piwacet Member
    SF Bay Area
    Shouldn't the insurance cover this type of event?
  5. Silicon Desert
    Silicon Desert Active Member
    Reno/Sparks Nevada
    Hmmm, strange. I'm not making the connection of a 12 V battery failure message relating to the main pack.
  6. CharleyBC
    CharleyBC Member
    Sacramento
    Your photo attachments didn't work.
  7. jebinc
    jebinc M3 LR AWD w/FSD and white premium interior
    Seattle, WA
    DITTO
  8. vickh
    vickh Member
    az
    I agree, comprehensive should cover this.
    I'm hoping the model Y underbelly is higher to avoid this road debris issue, maybe better protection would help too.
  9. Justinwaters
    Justinwaters Member
    Reno, NV
    Hey yall! My insurance does cover this but the tesla service people are being very sketchy about it, not answering my questions, making vague statements, pushing me to make a claim. It feels sketchy and i dont see how my battery (which was at full capacity still a month after hitting object) is effecting the 12 volt 402378 Waters.jpg 402378 Waters 2.jpg 402378 Waters 3.jpg 402378 Waters 4.jpg 402378 Waters 5.jpg
  10. COrocket
    COrocket Member
    Florida
    Yeah just tell them to replace the 12V and see if the problem is resolved. You didn’t take the car in for a new main battery.
  11. tomc603
    tomc603 Member
    NH, US
    Boy you sure understated the damage done. When you saw those scrapes the entire way down the length of your car, you really should have taken it to a shop. Either way, this is an insurance claim and a valuable lesson to drive around objects in the road and never over them. Sorry for your inconvenience, but at least getting a pack replaced is faster than an ICE engine.
  12. V__2
    V__2 Member
    FL
    Was the underbelly scraped or it had that part of the protection cover missing (in the last photo)?
    That ugly looking pointed up black piece do not seem to have punctured the plastic conduit. Is this a cooling line? I imagined those to be metal? What was the explanation for entire battery replacement? That it overheated?
  13. TomB985
    TomB985 Member
    Isanti, MN
    The damage appears pretty minor to me, where exactly are they saying the battery sustained damage?
  14. GreenMtnM3
    GreenMtnM3 Member
    Burlington, Vermont
    This is strange indeed. Your photos of the removed front plastic cover show that there are indeed some fairly fragile looking bits under there with minimal protection. So far, to me this seems to be the biggest design flaw on the car , a very low ground clearance combine with minimal protection for under-car parts. Perhaps there is an opportunity for aftermarket skid plates here?
    I live in New England, and our frost heave riddled roads often mean undercarriage bumps entering or leaving driveways. This vulnerability is a real concern !
  15. GolanB
    GolanB Supporting Member
    NYC
    13K sounds more like the lions share cost towards replacement of your main battery (not the 12V). Hopefully you'll get a detailed estimate, and can share back here. If it were me, I'd have another service center provide an estimate as well if you were suspicious that you were not getting accurate information. It would not make sense to me that Tesla would be costing out the replacement of the main battery unless there really was a serious issue.
  16. Justinwaters
    Justinwaters Member
    Reno, NV
    That black piece is touching that cooling line but did NOT puncture. update: its 15 thousand now.. and i dont know where else to take it to get an estimate? ill call and ask for a 12v replacement and update you guys.
  17. Krazaak
    Krazaak Member
    Charlotte, NC
    Unless there's damage internal to the battery compartment that isn't visible, I can't see why a pack replacement would be necessary. If there's any damage to the battery whatsoever though, it would be safest to replace it. At the very least, that metal needs to be bent so it doesn't contact the coolant hose and eventually wear through.
    12V is charged from the HV battery via DC/DC converter, so unless they can show that something is abnormal with the HV battery or DC/DC converter, it's probably just a failed 12V.
  18. ngogas
    ngogas Active Member
    Utah
    13k?! Did the service guy pocket 12,900.00?
