Undersized onboard L2 charger?
Discussion in 'Cybertruck: Battery & Charging' started by reedog117, Jan 17, 2020.
  1. reedog117
    reedog117 Member
    VA
    With the Gen 3 Wall Connector recently released with a max 48A current output, any thoughts on whether the Cybertruck will only accept 48A from an L2 charger? I would have thought especially with the high-capacity tri-motor that 80A charging would make a comeback.
  2. doghousePVD
    doghousePVD My grandfather’s car
    New England, USA
    Roadster 2 would want a c. 80 A charger, too.
  3. KBowden
    KBowden Member
    Socorro NM
    The problem with running those high currents is your household supply may not be able to handle it. I have a relatively high 200 amp service to my house. 48 amps is nearly 25%, then you add on AC load, Dryer, everything else running in the house and I might be overloading the service which may even be the transformer outside the house if the neighbors are also using a lot of power.
    • Disagree x 2
  4. quantumslip
    quantumslip Member
    Houston, TX
    People have installed the full 100A (80A continuous) Gen 2 HPWC with no issues; as long as the load calculations checks out there's no issue with having such a high powered charger. I wouldn't worry about overloading the transformer from the power company as I'm sure they're aware of the service size for each house and have an appropriate transformer for the houses; of course as more EVs come into market things may have to change.
    As for your scenario worse case (2 AC, 60 A if you have 2x large AC that's not the most efficient, electric dryer, 24A, electric stove 32A) + 48A EV = 164 amp, and that's only if everything is running full tilt at the same time. Lights and appliances other than the ones mentioned above shouldn't add too much more to the above In reality you would put everything through a load calculation to see if you need a service upgrade.
    As for the cybertruck itself, I do expect to see some sort of return of a higher power HPWC if I have to guess, especially if the trimotor is going to be more than 200kWh. (There's also the new roadster to think about as well).
  5. Eriamjh1138
    Eriamjh1138 Member
    Michigan
    IMHO, we will never see 80A charging on any future Teslas.
    • Disagree x 2
  6. kayak1
    kayak1 Member
    USA, The great state of Maine
    I have 200 AMP service. When I installed my solar I had to pay to upgrade the transformer at the street (not shared) from 10KW to 25KW as I was installing 24KW of Solar. My power company didn't provide an option of going with a larger transformer at the time. I would have to justify a larger transformer and pay for it if I was to expand my solar.
    I currently have two chargers, 5 heat pumps, a double electric oven, a well etc. I would worry about adding a 19KW car charger to the mix.
  7. doghousePVD
    New England, USA
    #7 doghousePVD, Aug 14, 2020
    If you are using your heavy loads during daylight (such as charging) there is no chance of over stressing your transformer. Also, it is very unlikely you would be using both ovens and the dryer and charging between 11pm and 6am.
    I would definitely install a 19kw charger.
  8. kayak1
    kayak1 Member
    Without the oven or the dryer running, we have used 18.77kw...
    I will have to see how things look this winter when we are using the heat pumps to heat the house now that we have the model Y.
  9. doghousePVD
    New England, USA
    [email protected] 240 volts is 48 kw. Each oven and dryer are probably 3kw. So 9 plus 19 is 28, leaving 20 to spare. Highly unlikely you would be using all of that continuously.
    You don’t have to always charge at full speed, either.
  10. kayak1
    kayak1 Member
    I do agree with that, I do agree that I have 200 amp service. Pre-solar that service was fed from a 10kw transformer. I had to pay to upgrade it to a 25kw transformer. I question how the 25kw transformer will behave with 40kw of load. (After the truck arrives I might just talk with the electric company and justify, then pay for another transformer upgrade. As the transformer is cheaper than PPF that I won't need for it. And just like PPF it provides peace of mind).
