Andyw2100
Thanks, I have not had the same success in similar situations, however I can only charge at a max of 32A (NEMA 14-50 with the crippled Canadian UMC adapter) so perhaps the higher current is what did it for you?
Could be.
I've always charged at 56 Amps, based on Cottonwood's suggestion, with an eye towards minimizing the heat and potential stress on the various components. (I do, of course, charge at 80 Amps if there's a reason to.) If it turns out that 56 Amp charging and leaving immediately takes the battery right to the borderline of no regen limits, depending on just how cold it is, I may experiment with kicking the Amps up to 64, to see if that winds up increasing the likelihood of leaving without a regen limit when it is even colder. I'm not sure if I'd want to go all the way to 80 Amps on a regular basis, though, even for just the winter. I know lots of people charge at 80 Amps 100% of the time, with no ill-effects, but I just like the idea of not pushing any of the system components too hard most of the time.
