Hello TMC,
Ive had MPP Sports on my P3D. I recently had the height adjusted to have some positive rake.
Fronts are set evenly on both sides
Rears are set evenly on both sides
Using 2 finger method I “measured” the gaps.
Front passenger is higher than front driver (difference is minuscule, probably due to a 170lb driver)
But the Rear passenger is noticeable higher than Rear driver.
I tried measuring in several “flat” parking lots, streets, garages and usually got the same results.
Any idea what the issue could be? I want to get this figured out before getting an alignment.
