uneven warm air coming out of the vents
Discussion in 'Model X' started by Willbebest, Dec 7, 2017.
Tags:
  1. Willbebest
    Willbebest Member
    Canada
    #1 Willbebest, Dec 7, 2017
    I have 2017 june made model x 5 seater.
    its my first winter with my tesla, last night when I turn on heating, i noticed that
    1. passenger side of front vents is significantly cooler than driver side vent.
    2. rear center vents air is cold, rare side vents also have freezing air coming out.
    (after 1.5 hours of driving, still the same)
    anybody else have the same issues?
  2. Panchratan
    Panchratan Member
    Memphis
    Yes: I do too. I haven't checked the temp in the back but my 6 seater (w/o center console) has cold air coming out through the front vents too with temp setting at 70F and outside temp at 46F!
  3. Willbebest
    Willbebest Member
    Canada
    i have warm air from front vents, its just uneven.
  4. jelloslug
    jelloslug Active Member
    Greenville, SC
    Are your temperatures set the same?
  5. Willbebest
    Willbebest Member
    Canada
    yes ofcourse
  6. jelloslug
    Greenville, SC
    Just checking...
  7. MXZoomZoom
    MXZoomZoom Member
    Palo Alto
    The AC in the X kind of sucks.
  8. alloverx
    alloverx Member
    Seattle
    AC technology is not new.
  9. monkeyhouse2
    monkeyhouse2 Member
    Woodcliff Lake, NJ
    I had this problem in my Model S, and I had service look at it several times and they could not duplicate the issue in their shop. When the heat is set for a middle-warm temperature (say 75-79 degrees), often times the air coming out of the driver side vents is warm and the air coming out of the passenger side vents is cool. Temperature settings for both sides were exactly the same. I really thought it was a flaw of some kind with my Model S because service had never heard of such an issue... but just the other day, the same exact behavior in my X. Now that I see it happens to other people too, it must be software related of some kind.
  10. MXZoomZoom
    MXZoomZoom Member
    Palo Alto
    They really need to hire better interns to build their AC software stack.
  11. Xcelerator
    Xcelerator Member
    Dallas
    The AC works fine, you just have to set it to temperatures a few degrees lower than you would in an ICE car. I was never hot in a typical Dallas summer, but, keep the temp on 68, which is about the equivalent of 73 in my wife's ICE car.
  12. ps004ynos
    ps004ynos Member
    Los Angeles
    I have a slightly different issue, the left drivers side middle row AC vent blows weaker/warmer relative to the right. I read about possible pinched hoses. SC looked and ordered a part but said backorderd. Been several months now :(.
