Unexpected Find
Rhytid
54
26
Maryland
I picked up my Performance 3 on 12/10/19. The weather around that time was very wet here in Maryland. Luckily, it was not very cold so even though I had to wait about a week or so to get my Winter tire/wheel set delivered from TireRack, I didn’t feel too bad about having to drive with the Michelin Summer tires the car came with. Once I got the Winter set, I swapped them out and had an uneventful Winter other than putting on almost 10k miles!!!
So the big surprise came when I went to change back to the Summer set this past weekend. As you can see in the pictures, it looks like the tire was plugged.
I know that I didn’t do that or have it done. So the question is, did Michelin do this or did Tesla?
I realize there is no way for me to prove that I didn’t do it. But considering I have 9860 miles on the car as of now and you can see by the treadwear on the tire, I think it’s pretty clear that I didn’t put a whole lot of miles on those Michelins. Odds of getting a flat with a couple of hundred miles is not 0% I understand but pretty low.
Unless I checked the tires at time of delivery, I wouldn’t have known until a later time. And to be honest, that’s not even something I thought NEEDED to be checked for.
The tire seems to have held pressure while in storage over the Winter and I don’t think it will be a big problem down the line but just somewhat surprised and frankly disappointed.
Just wanted to get it out there and off my chest.
jmaddr
860
853
Florida
So it's a rubber worm and not a shaved nail/screw? It looks like it could be a shaved nail or something harder than a rubber worm plug.
Move it around and see if you can get it out. It may be something that has not pierced the metal belt yet hence you didn't lose any air pressure.
Electric Dream
Pilots the Millennium Milkfloat
Jul 21, 2016
1,593
2,671
UK
How many miles had you done with that tyre? It still has the flashes across the tread! They'd be gone on mine after the first 100yds :D
I agree it doesn't look like a plug. It's a screw with the head snapped off or something similar. Best to get a tyre shop to take it out and really plug it.
Rhytid
54
26
Maryland
It doesn't feel like metal. Feels more like hard plastic.
I am afraid to try to pull it out in case it's a real plug. Then I am screwed.
Feathermerchan
1,098
843
Euless, Tx
If it is a plug and you pull it out, just replace it with a new one from your plugging kit.
Wait - you do not have a spare and you don't carry a plugging kit and compressor?
Electric Dream
Jul 21, 2016
1,593
2,671
UK
Whatever it is, It may only be in the tread a few mm, but in any case that's why I suggest taking it to a tyre shop so it can be pulled out and you can get it fixed if it needs to be.
gavine
Petrol Head turned EV Enthusiast
Apr 1, 2014
2,553
2,091
Philadelphia, PA
Put a magnet on it. I guess it could be an aluminum nail. How about if you tap on it with something hard. It looks metallic in the pictures. My first thought was that it was a nail.
Reactions: strykeroz
Garlan Garner
Banned
Mar 31, 2016
11,351
6,062
Chicagoland
View attachment 530234 View attachment 530235 View attachment 530234 I picked up my Performance 3 on 12/10/19. The weather around that time was very wet here in Maryland. Luckily, it was not very cold so even though I had to wait about a week or so to get my Winter tire/wheel set delivered from TireRack, I didn’t feel too bad about having to drive with the Michelin Summer tires the car came with. Once I got the Winter set, I swapped them out and had an uneventful Winter other than putting on almost 10k miles!!!
I wouldn't put that tire back on my car without knowing if its a plug or a plastic screw or something.
Take it to a tire shop....have them pull it out....and re-plug it if necessary.
Very inexpensive and quick endeavor.
MP3Mike
14,978
31,851
Oregon
You should be able to probe it with something sharp to see if you can scratch it or if it is rubber. If it is hard plastic or metal, it isn't a plug...
Reactions: SomeJoe7777
KenC
3,278
2,993
Maine
Looks like a nail, with the head worn down, to me. I once had a deck nail, they're short, in a tire on my BMW. Slow leak, pulled it out and plugged it.
Reactions: gaswalla
ZOMGVTEK
558
433
'Merica
The odds the car was intentionally delivered to you with a plug in a tire is not something I’d bet on. 10k miles is plenty to run over something.
Either way, there’s no way to prove it. It does look more like a nail to me, but I’d be curious to see if it really is a rubber plug.
CharleyBC
1,380
1,551
Talent, OR
The tire is obviously nearly brand new, as you said. I bet you picked up something in that first week before you got your winters on. I agree with the dominant theme here: Take it to a tire shop, and pull out whatever it is, and then fix if needed. Or pull it yourself and take it to the tire shop if that opens a leak.
Rhytid
54
26
Maryland
OK. Thanks everyone for the input. So came home and took the wheel off and pried the thing out. Not sure if you can tell in the picture but it was a piece of hard plastic. Dug around a little after removing and did not feel anything else in the wound. No leak.
Glad to have resolution and also thankful for the resource such as this board.
Also very happy that my fears about Michelin and Tesla were completely unfounded.
mongo
12,865
37,837
Michigan
View attachment 530444 View attachment 530445
Glad it wasn't anything serious.
Thanks for the update and closure!
