Unintended Acceleration Complaint
Discussion in 'Model S: Driving Dynamics' started by mnx, Sep 25, 2013.
  1. JPP
    JPP Active Member
    SF Bay Area, CA
    Remember a while back when Audi almost went under due to a rash of 'unintended acceleration' cases that eventually were shown to be 'pedal misapplication' and the implementation of shift locks (need to be pressing the brake to shift into Drive). And this was in the day of 'mechanical' throttles and transmissions, unlike the more recent Toyota issues. If I recall correctly, one of the things Audi did (before the advent of fully telemetered vehicles) was to place video cameras pointing to the pedals and the driver and do a lot of real world testing to see how people drove and if any events occurred that could not be attributed to driver error.
  2. jerry33
    Texas
    The first cars that I drove had the gas pedal hinged on the floor. The mats always rode up on it (as did pop bottles--and sometimes they rolled under the brake pedal). It was/is the responsibility of the driver to check for those things.
  3. deonb
    deonb Supporting Member
    Redmond, WA
    The Model S floor mats are particularly horrible. I have to adjust mine daily, since they keep riding up to the pedals. I can't believe they didn't have those floormat locks that Toyota has. It's a matter of time before they will cause an accident for someone.
    I originally thought I had the original floormats and that the new ones are better, but when I went to the service center last, they said I already had the new ones.
  4. tpoltron
    tpoltron Member
    Cupertino, CA
    I've accidentally run this test a couple times when I've had big flip flops on. The dash display beeps and says "both pedals pressed" and the car doesn't go anywhere.
  5. brianstorms
    brianstorms Member
    That's interesting, in the ~2000 miles I've had w/ my car so far, never had a single floor mat issue.
  6. Discoducky
    Discoducky Active Member
    Seattle
    All weather floor mats from TM have anchors for the drivers mat.
  7. markwj
    markwj Moderator, Asia Pacific
    Hong Kong
    It is a sad reality that these unintended feedback loops exists. If the car accelerates when you press what you think is the brake pedal, your natural instinct is to press harder on the brake, which (as it is the accelerator) makes the situation dramatically worse. In my technical scuba diving world, I've lost several friends to just such a feedback loop.
    Design and engineering can sometimes break these feedback loops, but in this case I don't see how the car can differentiate between intended and unintended acceleration when you press the accelerator pedal and not the brake. Sure, it could limit acceleration, but that in itself can be dangerous (as sometimes you need that acceleration to avoid a problem).
    If this was me:
    1. Make sure everyone is ok. The car can be repaired/replaced, humans often not.
    2. Get the logs, and review them to see what pedal was pressed when.
    3. If it was always the accelerator pedal and not the brake, then fess up and move on.
    4. If the brake was pressed in any way, then raise the complaint.
    I fail to see how 92% vs 100% accelerator is relevant.
  8. stopcrazypp
    stopcrazypp Well-Known Member
    That's mainly to discredit the Tesla engineer's explanation.
  9. AC1K
    AC1K Member
    Calgary Alberta Canada
    i blame the driver, its obvious the woman didnt know how to drive a car, im pretty sure she was on the accelerator pedal while doing heavy regen, and when she wasnt slowing down fast enough with regen she floor the pedal telling the amp controller to deliver max power.
    and also, both pedals = NO MOVEMENT
  10. Dragonfly
    Dragonfly Member
    Moorhead, Minnesota, United States
    In the court of public opinion, the nature of the evidence is irrelevant; it's the seriousness of the charge that matters. I may be a conspiracy theorist, but I smell the ingredients of a negative PR campaign. I'm not making any accusations, but the state dealer associations and big 3 haven't been too keen on Tesla the past few months. The charge is out there. The rumor mill has started. Even if NHTSA investigates and finds it was driver error, the media will most likely not report that, so the rumor will remain that your Tesla will take off without you.
    Anyone on here know the owner/driver? Perhaps they could come on here and state their case to those of us who know the car the best?
  11. brianstorms
    brianstorms Member
    [OT, on a quick side note -- how does one get the driver's display to show things this way, with energy consumption on the left, and trip data on the right? Is this a 4.5-and-earlier firmware thing? My car came with 5.0, and my left-hand region of the display stays blank unless I have audio playing (I don't have parking sensors), and the right-hand area shows energy consumption. I have never figured out how to get trip data to display in the driver's display.]
  12. GDH
    GDH Banned
    Portland, OR
    #32 GDH, Sep 25, 2013
    Man you people are paranoid
  13. mcornwell
    mcornwell Active Member
    Brian-
    Hold down the left scroll wheel for a few seconds, when the display to the left of the speedo changes, release the scroll wheel and select what you want to see (energy chart, odometer, audio info), then press the scroll wheel in again.
    Do the same for the right side.
    -Mike
  14. brianman
    brianman Burrito Founder
    No, it's not "obvious ...". Don't follow bad behavior with bad behavior please.
    My current guess is that her foot slipped from one pedal to another (perhaps bad driving shoes?) and nothing more.
  15. cwerdna
    cwerdna Active Member
    SF Bay Area, CA
    Yep.
    The piece at Smart pedals won’t put the brakes on driver error / UCLA Today covers basically this and numerous scenarios.
  16. montgom626
    montgom626 Active Member
    Can anyone tell me how this post has anything to do with Unintended Acceleration Complaint???
    - - - Updated - - -
    Tesla can pull the logs in a matter of seconds after any incident.
  17. vfx
    vfx Well-Known Member
    CA CA
    Compounded by the instant acceleration of an EV.
  18. FlasherZ
    #38 FlasherZ, Sep 30, 2013
    Unfortunately, these things will happen, especially given those who insist that instead of working with the manufacturer, someone who experiences an incident should run straight to the government to report these things. Then there will be those who insist that it must be the technology, not human error, and will disagree with Tesla and file a claim.
    The good news is the mainstream press understands this and usually reports on this when it becomes a pervasive problem. Unfortunately, bloggers tend not to, and so "quick-hit" pieces pop up easily, while having to eat crow when it turns out to be that the driver pressed the wrong pedal.
    From past incidents, it is clear that the car logs a very, very good collection of information. Tesla just doesn't access that information without your permission, although if the data is subpoenaed, access will happen.
  19. SFOTurtle
    SFOTurtle Active Member
    Los Altos, CA
    +1 with 10K miles on the car, although I had mine replaced about 3 months ago when Tesla installed the mats for the rear seats. Up until that time I never had a problem with the driver's side mat, but the front right mat did keep folding over on itself. The new one doesn't have that problem.
  20. deonb
    Redmond, WA
    Did Tesla replace the front floor mats for you? Or did you buy after-market?
    When Tesla installed the rear mats, they said my car already had the new front floor mats. However, my VIN is 600 before yours.
    Is there an easy way to identity which "generation" of floor mat a car has?
