Hi, I got the 2021.24.5 update last night, but as far as I could tell, the charge port behaviour this morning was just the same as it was before the update - I still needed to use the app or dashboard screen to unlock the charge port before the cable could be removed. So I've not cancelled my order for the
Tesla mini connector kit - evChargeking that
@Cardo suggested.
Thanks for pointing out this kit
@Cardo. It arrived from evChargeking in 5 days (including the weekend) and was simple enough to fit. Inside the existing plug was a resistor between wires connected to the earth and proximity terminals. That has to be cut off, and then I soldered the switch wires to those disconnected ones. The kit includes shrink sleeves to cover the joints - I have no heat gun, but it wasn't hard to carefully hold a match underneath to do that part. And those were the only slightly tricky bits! The rest just involved unscrewing the two halves of previous plug body and then refitting with the replacement. Easy.
And it works so simply. So this morning I opened the garage door with my phone in the back pocket of my jeans (so not yet sensed by the car), and the car was asleep. The light on the charge port was unlit. As expected, pressing the button on the plug had no effect at this point, as I guessed the car needed to be awake first, and ready to unlock.
Opening the boot would have woken it up. Instead I pulled the boot latch: as I expected, the boot didn't open, but it woke the car. Since my phone was still in the back pocket of my jeans the car wasn't prepared to unlock - if I'd wanted the boot to open I'd have taken my phone out of my pocket, or turned my backside to the car(!) before pulling the latch so the car could sense my phone.
As soon as the car woke, the charge port light came on green to indicate that the car was charged up to the limit. Now pressing the cable plug button released the plug, but by this stage the car must have also sensed the proximity of my phone, even though it was still in my back pocket. So the car went ahead and released the cable, and also reported on the dashboard that it had unlocked.
I replugged the cable, locked the car and went back later without my phone on me to check that last point - that If it couldn't sense my phone, it wouldn't release the cable. That's exactly what happened. Pulling the boot latch woke the car up. Now on pressing the charge cable button the dashboard would message that I needed to "tap the keycard to unlock", and the cable remained firmly locked in. All entirely reassuring!
I didn't pay proper attention this morning but I think the cable was released before I actually pressed the app button i.e. when the app/car became awake as I was standing next to the car. Mind you the app used to be able to release the cable before the car was properly awake anyway. I'll pay better attention tomorrow to see if the behaviour has changed!
(on 24.5)
I've still seen no change with 2021.24.5 from what happened before - any update?
