Unnecessary saving of the profile
Anyone else notice that whenever you "start" the car, and the driver profile switches from easy entry to the appropriate profile, that it shows "saving" several times up at the top? I know as part of V10 there was an enhancement to the driver profile where it would show you "saving" when a change was made, but if I'm just going from easy entry to my profile, I wouldn't think it should be saving any changes. It appears to do this several times during the switch.
Reactions: Silicon Desert
David29
2,487
2,132
DEDHAM, MA
Has anyone noticed failures to save changes to the profiles? I have a loaner 2018 Model S that has Version 10 (32.12.2). I have tried numerous times over the past few days to set it up so that the right-hand outside mirror will turn down when the car reverses, to no avail. I have selected automatic tilt in the settings. In revers, I adjust the mirror and press "Save." But next time i back up, it does not tilt down. Plus, it does not always return to the normal position when I put it into Drive again. There is some inconsistency, but generally I cannot save the tilted position.
