UNOFFICIAL: Bluestar Pricing and Options
Discussion in 'Model 3' started by VolkerP, Jan 19, 2012.
Tags:
  1. Kevin Harney
    Kevin Harney Active Member
    Herndon, VA
    I am also disappointed in his battery sizes. I hope that they are slightly larger than that. I would need a 300 mile option at the top for my needs.
  2. Kevin Harney
    Herndon, VA
    For the Model C I think it will be a bit longer in wheel base and length. It needs 0-60 times of at least 4.5- 5.5. It needs a max range of 300 miles (for me anyway). Top speed needs to be in the 155mph range on the sport version. It will need to come in 3 variants sedan/ coupe and convertible with a sport option on all 3. And it needs to start at about $35,000 not including the $7,500 rebate which would mean they could advertise starting at $27,500 if they wanted. I think a loaded sport version could easily be in the $75-$85K range. Attached are the dimensions of the BMW just for reference.
  3. VolkerP
    VolkerP EU Model S P-37
    Germany
    Thanks a lot for your input, Kevin, and everybody else.
    Many forum contributions went into the compilation of this bluestar data sheet. I made up a few numbers to make it look plausible but apparently it is impossible to please every one. Below follows a compilation of counter proposals that actually where backed up by data, argumentation, or other references.
    I picked the Roadster as a premium price-able vehicle for the introduction of the bluestar platform, with the sedan as the follow-up to tap into that rather large market segment. If you want to discuss a coupe or a convertible, you should find a good reason why Tesla would want to do these before a sedan class vehicle and why they should follow immediately after a convertible based on the skateboard (Model S) platform.
    AWD and sport options for all models surely is in discussion but it would blow up the table. Perhaps I list them as separate options?
    The 3 door strategy is a common approach in EU market for entry level models with upgrade option for 5 doors. But it was very badly received here. Everybody wants a 5 door hatchback, no one sees the possibility to save a few grand here. OK. Ditched.
    I suggest to discuss pricing after a consensus on other properties has emerged. E.g. shaving off 1s of 0-60 times will allow to sell the sport variant for $10k more in US market. In Europe, no one gives a cr*p on 0-60 for a family sedan with the exception of motor journalists and top gear fans :tongue:
    Dimensions
    Thanks to Kevin for supplying the BMW 3 series dimensions. Franz von Holzhausen has stated that the Model S has to look like a conventional sedan. With bluestar, Tesla can start to explore more of the freedom that an electric drive train allows. There is no need for an excessive 8cu ft frunk to make it look like a front ICE vehicle. richkae pointed out that more vehicle back length can benefit aerodynamics. Thus I suggest to start from the exterior dimensions of the BMW 3, move the cabin forward, and stretch the wheel base. Anyone willing to provide some artwork?
    so: wheel base: BMW3: 108, Model S: 116, Model C+R 104->112. Will fiddle with the rest.
    Battery and Drive Train Specifications
    Now this is where the battle is won or lost. Don't tell me you want 300 miles. Everybody wants 300 until he sees the penalty for that. Please provide a reasonable suggestion on which sweet spot Tesla must aim to make bluestar a success. Constraints are price, weight, availability of higher capacity cells, maximum charge and discharge power, resulting in 0-60 time and curb weight. Please solve for x.
    No one commented on the cell sizes I listed, so these look ok.
    Thanks for comparing pack capacity and curb weight with Roadster data. This should be a valid data point to adjust estimations.
    I liked the comment that Model C variants don't need >200kW peak power. I will combine that with the idea to describe performance models as a separate option.
    Charging options
    Thanks to jkirkebo for pointing out the CHAdeMO option price for the LEAF. Will change $4,500 to $700, accordingly. Tesla will get called names if they try to introduce a price penalty for a charging standard that they see in competition with their own proposal. :biggrin:
    Stay tuned for updates!
    Vehicle Size and dimensions
  4. vfx
    vfx Well-Known Member
    CA CA
    The term "Bluestar" is ours. (I like to take credit for making that name up (Galaxina reference)) If you talk with Tesla people and mention"Bluestar" without putting it onto context, many have no idea what you are talking about.
    There will likely be yet another S platform car before we see the smaller skateboard.
  5. richkae
    richkae VIN587
    The best way to reduce cost of the Model C is to improve the Wh/mile. That needs to be foremost in design goals.
    1. Improve aerodynamics by reducing cross section ( width and height ) making for a smaller car.
    2. Improve aerodynamics by not using ridiculous giant wheels and giant wheel wells. This has the additional advantages of reducing weight and improving interior space.
    3. Improve rolling resistance by not using ridiculous giant wheels.
    4. Reduce mass. Once you're all aluminum, you have to make the car smaller. This may conflict with point 1 because a short tall car may have less mass, but worse aerodynamics.
    I'm harping on the giant wheels, because I think they are one of the worst features of the Model S in terms of efficiency - although everyone seems to agree they look good.
    If you build the car around smaller wheels then you can pack a lot of space into an 108 or less inch wheelbase.
  6. AnOutsider
    AnOutsider S532 # XS27
    How many luxury cars have small dinky wheels though? They did it right by making the car attractive first, EV second.
  7. richkae
    richkae VIN587
    I didn't say they made the wrong choice for the Model S, just that it has a negative impact on efficiency.
  8. Eberhard
    Eberhard #421 Model S #S32
    Germany
    the roadster has 56kWh, with the new chemistry (3.1) has around 80kWh.
  9. richkae
    richkae VIN587
    If you reduce the wheelbase of the Model S from 116 to 108 and reduce the track ( width ) about 6 inches from 66 to 60 you have reduced the footprint available to the battery by about 18-20%
    However if you reduce the wheel openings down from fitting 21s to 15s you actually get some of the space inside the wheelbase back - so maybe your battery box is only 15% smaller.
    If you can improve the Wh/mile of the car by 15% then you can have a 300 mile range car with a 72kWh battery ( 15% smaller than 85kWh ).
    Although I'm not saying that 300 mile range should necessarily be offered on the Model C.
  10. Norbert
    Norbert TSLA will win
    San Francisco, CA
    Also, even the cells used in the MODEL S, 85 kWh version, leave some space in the pack.
  11. ElSupreme
    ElSupreme Model S 03182
    Atlanta, GA
    One note about the wheel size. As an avid cyclist there is an absurd amount of aerodynamic data on wheel size. In general smaller wheels do NOT equate to less drag, but more. This is because the linear velocity is the same on both wheels, and because the wheel actually turns over more (more RPMs) and churns up more air. Granted on a wheel shrouded vehicle this is a different case. And the larger the wheel well the worse aerodynamics you will be seeing.
    Granted the Model S does have ridiculous giant wheels. I thought the 18" wheels on my GTI were stupid big. I downgraded to the 17" ones and have saved thousands on replacement tires (they only seem to make it ~25,000km)!
  12. vfx
    CA CA
    We have talked before about "stacking" two battery packs for more range.
    If you look at the briefcase sized lump at the rear (right) of the battery pack here.
    That is a space that contains more batteries. The engineer at Freemont said they had some extra space so they took it.
    Same could be done for the next platform.
  13. ManuVince
    ManuVince Member
    Netherlands
    I would go for a nice compromise like the Audi A3 SportBack. A little longer than the VW Golf, so offering more boot space. Not the most sexy for sure, but the best compromise between a small hatch and a sedan. And it would look very nice and sporty with 17" wheels.
    For a 101" wheel base, with the Tesla skate board chassis, you can get much more space than what Audi gets. With a body inspired by the Model S that would be a really hot hatch !
  14. neroden
    neroden Model S Owner and Frustrated Tesla Fan
    Ithaca, NY, USA
    I'm not going to speculate on the nature of the Bluestar except for *one* thing: it's not going to be called "model C".
    It's going to be called "Model T". Elon has the chutzpah for it.
  15. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
  16. Grendal
    Grendal SpaceX Moderator
    Santa Fe, New Mexico
    Very nice. But I think Model E for Economy/Everyman car would also work.
  17. Robert.Boston
    Robert.Boston Model S VIN P01536
    Portland, Maine, USA
    The, err, "Volkswagon"?
  18. marcon
    marcon Member
    Germany
    Touch Screen will stay 17"
    1. There is very little to no financial advantages to use a smaller screen compared to the system costs of the car.
    2. The Tesla OS is optimised for 17". A smaller screen would mean for Tesla to maintain several different layouts of pretty much the whole OS, otherwise buttons would be too small to use easily. There is a reason Apple kept the iphone's screen size fixed for 5 years. Tesla will try to use as many synergies as possible, not to reduce these. Keep in mind that they are planning to keep the software current for years to come.
    3. Reducing the screen size will probably necessitate more physical buttons. Basing a system around non-touch controls also reduces the upgradability of the OS greatly. Teslas design language tries to remove as much clutter as possible. There are only two physical buttons on the dashboard. However, they are in talks with Google to use their voice recognition software, which would reduce the need for physical buttons.
    4. Pretty much all reviews of the Model S praise the large touchscreen. This is one of the features of the car that seems to shout paradigm shift the loudest. Tesla is a very forward thinking company and won't want to implement "yesterdays" technology (read: the way it has been done in the last 50 years.)
    5. It is unlikely that a smaller screen will make it easier to use. Conversly, if the feedback from Tesla users points to difficulty of use, it would argue for an even larger screen. However, since the screen is already occupying most of the available space, that is probably also unlikely.
    6. It is easy to differentiate between high and low cost interiors by using screens of different qualities, i.e. resolution, viewing angles, colour representation, OLEDs etc. (retina mac book pro vs original mac book pro, retina ipad 4 vs ipad 2)
  19. brianman
    brianman Burrito Founder
    I don't expect that feedback. My only real complaint about the screen so far is that I want an easy way (button in the climate control block would be great) to turn the 17 into screensaver / black mode at night. Similarly, I've sometimes put the left and right sides of the dash screen to "Empty" to mute it down as well when driving at night.
  20. Vger
    Vger Active Member
    Salt Spring Island, BC, Canada
    I don't know what the pixel pitch is on the current screen, but Tesla could consider reducing the physical size of the panel without reducing the pixel count. This is what Apple cleverly did with the iPad Mini. A smaller physical size might really make sense in a considerably smaller cabin, especially in a new-generation Roadster or possible smaller coupe model. Elon has said that the size template for even the Gen III sedan is the BMW 3 or Audi A4. Thinking about those cabins, a 17" screen would be quite out of proportion. Perhaps a 14" or 15" screen with equal pixel count would make more sense.
