Looking to get some springs to lower my MYP when it comes in. I'm fairly certain I want to get them from UPP (the Eibach lower the rear more, which I find odd).
I'm interested in a lowered look, improved handling and a smoother ride. With that said, I was going to play it safe and order the mild version. However, I read the description on their site that states the moderate version should also feel "more comfortable around town". I copied the description below.
Does anyone have experience with either? Thoughts on how it handled? How comfortable the ride was? Did it really improve range, as stated in the final bit I copied below?
- Moderate provides an approximate 1.5″ drop on non-performance Model Y trims and an approximate 1″ drop on the Model Y Performance with slightly more comfort around town and significantly sportier handling in corners.
- Mild provides an approximate 1″ drop on non-performance Model Y and an approximate 0.5″ drop on the Model Y Performance with more comfort around town and sportier handling in corners.
AERODYNAMICS:
- During our comprehensive aerodynamic study of Model 3, we tested the efficacy of our Dual Rate Linear Lowering Springs using CFD, and the results were dramatic. After installation of the Moderate Version of our Dual Rate Linear Lowering Springs (1.5″ lower ride height), a decrease of 8.1% in total vehicle drag resulted, with a reduction of the total vehicle drag coefficient by 0.019 (factory ride height = 28.5″ baseline, measured at the center of the front fender).
