Update fails to Install
Birdman325
901
543
Toronto, Canada
Has anyone had an update start and then just fail to install? I took my car in for service today and they pushed the latest update. But every time I try to install it, it starts but then cancels and says it failed to install.
I have done a reset and tried it again with the same result.
Any thoughts?
RayK
1,837
1,788
San Jose, CA
Ask for a reformat of the SD card. According to what I was told by Sunnyvale SC, that's what worked for me.
This is assuming that your car is connected to Wi-Fi during the update process..
Reactions: gaswalla
Amendale
178
181
Toronto, Ontario
I too took my car in for service recently and got it back with an update prompt, only to find that the update fails to install. Not sure what to make of it, but not a huge concern
gaswalla
Model S,3,X.. CT with Austin delivery
Sep 23, 2012
3,253
3,523
San Diego
Early 3's had an issue with the SD card as mentioned. Would cause failed firmware updates. Just call Tesla and let them know - this is easily fixed remotely
TexasEV
7,641
8,469
Austin, TX
No, don't ask for a reformat of the SD card. Just because that was someone's issue doesn't mean it's yours. You can't diagnose the problem but Tesla can. Just call and tell them your update failed and they'll take it from there. When an update failed on my Model S several years ago they pushed the update again and it worked. But a different car may have had a different problem.
boaterva
7,562
3,736
Northern Virginia, USA
Had this recently when 2019.5.15 failed to install. Tesla has to restart/reset the install. It worked on the second try but I had to ‘wake up’ the car using the app (using unlock) since they couldn’t access it and I couldn’t reboot it. They said they had a few instances of these. Something about boot loader failure.
Something to keep in mind that the app has access even when the car seems dead sometimes!
