Why would you presume the car has power??? If it has power, there's likely no need for a manual door release anyway.
I'm talking about in normal use when you accidentally or purposefully activate the manual releases. The Model 3/Y pops down the window using the door ajar sensor (was changed in an update after people complained about damaging trim). That makes so you only risk doing so when the car has no power, in which case, damaging the trim is a small price to pay (as most likely it's an emergency).
I think you really don't grasp the concept. The first issue is that no small number of people will simply not be capable of climbing through from one seat to the other. The other issue is that it is not reasonable to expect everyone in the car will be "trained" to climb to the front seat to exit the car in an emergency. People panic easily, not because they are weak in any way, but because being trapped is exactly the sort of thing that causes panic.
So please stop talking nonsense about "training" people. This reminds me of the Congressional inquiry into safety in autos in the 60's where an automotive executive talked about training his kids to brace against the dash board with their arms when he yelled, "ARMS!"
I'm not talking about training people, just making them aware that's likely the most viable exit method in many cases, instead of wasting time struggling to open the rear doors.
Or simply designing the cars so they do not require special training to exit in an emergency. The glass brake tool is intended for those accidents where doors are jammed, not for cars that are designed in ways that prevent exit because of an electrical failure.
It's irrelevant if the inability of the door to open is because the door is jammed/deformed, the internal latch mechanism broke, the door handle broke, child locks are on, an electrical failure, or any other reason why you can't open the door, the glass break tool gives you an extra option to exit the vehicle, if that is a huge concern for you.
What is wrong with a manual door release that releases the door? It's not the frameless window.
It's definitely the reason in the Model 3/Y however, as it uses a design where the trim/weather seal can be damaged if you don't let the window drop. Using an electronic release ensures that never happens, as it allows the car to always drop the window before the door is pushed open. Then there is a secondary manual release for the front doors for emergencies. This design is not unique to Tesla, and had been used before in other cars.
I've seen frameless designs that don't require lowering the window to open the door.
I remember reading an article in the past that mentioned frameless designs that don't drop the windows (couldn't find it again in my search), and there were compromises made in those kinds of designs (don't remember if it was wind noise or weather sealing), which is why most frameless designs today slip the windows into the trim/seal (and drop the windows down slightly when opening). It's a balance of issues to consider in engineering. That's the point I'm trying to make. You aren't only considering one thing in a design: namely exiting the vehicle without power (which is something that rarely happens), you also have to consider the factors that affect daily use and may be far more significant for most users (like louder wind noise, worse weather sealing, or increased door opening resistance).
No, it's only the nature of the beast when it is designed so the sensors fall off the door or the buttons break. I understand the model S has a weak part in the door handle that costs hundreds of dollars to have fixed and it just continues to break. It's one thing to design a flaw, but to continue to make the same flawed part is not excusable, especially in a $100,000 car.
Others already point out actually Tesla had gone through multiple revisions of the Model S door handle design. The latest part eliminates many components in the design and makes the part much simpler and less prone to failure.
Here's a great video that goes over the changes if you are interested in the engineering:
In the Model S case, that handle design was mostly gimmick (could have been replaced by a much simpler solution like in Model 3/Y for the same aero advantages). In the Model X, the rear door design really does have unique usages, even though it is drastically more complicated than regular doors.
Again, other cars are not the issue. Many, many cars had serious design defects that cost lives in the 60s and 70s, but Ford got their asses sued off because of the Pinto mostly because it was an easy case to prove. Same here.
About 2-3 years into its production (1973) the Pinto already started having reports of fire in rear end crashes. By mid 1974, there was a lawsuit where 4 deaths and 3 serious injuries were tied to its design.
Ford Pinto - Wikipedia
Sure, if the prevalence of accidents where rear door exit played a huge factor reaches such a level for Teslas, there might be some probability of pressure on Tesla, but again, given there are far more cars with worse rear exit designs (designs that you can't easily exit even when car has power) and no evidence it is considered an issue that requires banning such designs, I find that probability extremely low. Especially given the specifics in Teslas narrows things such that it only plays a factor in accidents severe enough to disable the 12V system, but yet the rear doors are not damaged enough to still be able to open on their own, plus the rear passengers are conscious and able enough to exit on their own.
I feel so special that my death trap doors are not as bad as your death trap doors. How many Pintos did they sell before the law suits started rolling in? These days there are Federal agencies that tend to be the tip of the spear for this sort of thing. We'll see how they handle it. With the publicity of EV fires (deserved or not) difficult to open doors get attention very readily. This is not a closed matter.
They sold about 1.5-2 million Pintos before the lawsuits started rolling in (the recall in 1978 was also around that many vehicles). Tesla had passed the 2 million mark recently. But again the amount of cars with difficult or impossible to open rear doors greatly surpasses this number (again, I point to coupes, extended cab trucks, multiple Mazda vehicles, the i3, and the rest of the ones on the following list).
Autotrader - page unavailable
I just find it hard to believe if a ban have not been triggered for those cars, suddenly it would be for Tesla.
