Upgrade 60 to 90
Discussion in 'Model S: Battery & Charging' started by iridium, Jul 18, 2015.
  1. iridium
    iridium Member
    Scottsdale, AZ
    So now that a 90kwh pack has been announced, I wonder if it will be possible to upgrade a 60 to a 90. I suspect no, but am hopeful.
  2. S85D
    S85D Member
    Austin, TX
    The Tesla website say that the $3,000 90Kw upgrade is only for the 85Kw battery. I would think it would be possible to purchase the new 90Kw battery and replace your 60Kw battery. Probably very expensive.
    I just got my S85D 6 weeks ago and wish I had the option when I purchased it to get the 90Kw battery. :-(
  3. thegruf
    thegruf Active Member
    indeterminate
    afaik the answer is No.
    Tesla have stated you cannot upgrade one model to another.
    If you think about it, it is a complete minefield for Tesla to manage exchanging used parts of unknown condition, plus there are undoubtedly many other items than just the battery to switch out, plus I believe Tesla do consider protecting existing owners of higher performance models.
    Sell and re-buy a higher spec model would be just as cost effective anyway.
  4. David-El
    David-El Model S - P3078
    Fremont, CA
    There's a post on here somewhere that talks about an owner who bought a 60 and upgraded it to a P85, with the cost of upgrading from a 60 to an 85 battery pack being about $18k (cost of 85 battery - value of 60 battery). They then paid to have the drivetrain replaced with the Performance one, so it is possible. Things that are not possible are upgrading from Single motor to Dual motor and adding Autopilot. But from everything I've read, most things are possible, it's just the cost that owners have to consider.
  5. Saghost
    Saghost Well-Known Member
    Delaware
    Used parts of unknown condition? Tesla certainly knows what condition the car's battery is in better than the owner does, with the way the cars always phone home. There's no reason they couldn't pull logs to get an updated status when a customer requests a quote, and then quote them a price based on the actual condition of the pack, if they chose to.
    I'm not sure what else you're thinking would be switched out - the motors and inverters are the same, likewise the charger modules. You might need a firmware update, but all the components that need changing are in the battery pack assembly.
    I'm also not sure what protection you think higher performance model owners need here - buying the lower spec car and the battery upgrade will certainly be more expensive than buying the higher spec car, without and manipulation of the pack price by Tesla.
    My guess is that once the Gigafactory gets rolling you'll see Tesla embracing this extra business - until then they don't want to trade car sales for battery sales.
    Walter
  6. Torben_E
    Torben_E Member
    Denmark
    I guess if you go from a 60 kWh to a 85 or 90 you have to change the inverter and motor as the voltage is 350 vs 400 on the dc part.
    Down the line I am convinced there will come an batt upgrade program.
    Cheers Torben_E
  7. rlang59
    rlang59 Member
    US
    The 60 and 85 have the same drive unit.
  8. yobigd20
    yobigd20 Well-Known Member
    Skaneateles, NY
    ignore this, sorry wrong post haah
  9. glhs272
    glhs272 Unnamed plug faced villian
    Burlington, WI
    Upgrading to a 90kwh from a 60kwh is perfectly doable. Just needs a suspension components upgrade and a whole lot of cash!
