I don't believe any carbon ceramic rotors are compatible with the factory calipers.
First of all, there are not many 14" carbon ceramic rotors available.
Of the ones that are available, most are much thicker than 1".
The factory Performance Upgrade brake calipers can only fit 26-27mm thick rotors at the most.
To get carbon ceramic brakes will require a full upgrade of calipers, pads, and rotors (and lines and fluid while you're at it).
The Unpugged Performance carbon ceramic upgrade looks like it is pieced together from Corvette ZR1 OEM parts which are made by Brembo. These parts can be had for much cheaper by looking around online and getting a custom aluminum had made for the rotors.
