Upgrades to the OG Roadster Post Yours
Discussion in 'Roadster: Performance' started by Sky#277, Apr 21, 2019.
  1. glight2000
    glight2000 Member
    San Diego, CA
    OMG, very nice work on the Roadster. I also live in SD and would love to see it in person sometime. Unfortunately, I think we’ll be on a family vacation while you’re at the car show. Nonetheless, I love your mods!
  2. Sky#277
    Sky#277 Member
    San Diego, CA
    Sure. I reverted back to the original instrument cluster and took out the sound for now. I want to find some better speakers. Its not much but its all cool. I went with a carbon fiber top on the original instrument panel from the elise shop. I was thinking of doing the whole dash and front air conditioning and airbag cover with the carbon fiber at some point. it would fit right in. Where in SD you live?
  3. glight2000
    glight2000 Member
    San Diego, CA
    I live in Eastlake but work at UCSD in La Jolla and Hillcrest. How about you?
  4. Sky#277
    Sky#277 Member
    San Diego, CA
    I love downtown but used to live in OTay ranch. What u got planned for the holidays? I’m trying to get my car started it won’t move from park at the moment after they put the quick charge mod on. Know anything it might be?
  5. Roadster
    Roadster JdeMO Powered
    SoCal
    You may want to try rebooting the VMS. If that doesn't work, reach out to @TonyWilliams at QCP directly. He'll help you sort out your JdeMO issue.
  6. Sky#277
    Sky#277 Member
    San Diego, CA
    Tried that and been working with Tony and Alex and can't seem to figure out what it is. Went there myself today and rebooted it and nothing. Just all accessories turn on and the park light is flashing red and cant shift to any gear.
  7. Sky#277
    Sky#277 Member
    San Diego, CA
    Only thing i did notice is that the covers that protect the battery are not put back on, but they have no connections. Could it be the transmission control module fuse or maybe it just has some sensor that detects the battery panels are off?
  8. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    On the 2.X PEM at least the high voltage access door has a mice switch that will throw an error and not go into drive if the cover is off
  9. Sky#277
    Sky#277 Member
    San Diego, CA
    That makes sense. I know it’s hmjust metal and some plastic but I bet once it’s put back on it will be fine.
  10. DrivingTheFuture
    United States
    Did you get this sorted out? :-/
  11. Sky#277
    Sky#277 Member
    San Diego, CA
    Yes, It was a PEM interlock mechanism that wasn't seated right when they were working on it. The charging system is amazing.
  12. CM_007
    CM_007 Carl Medlock
    WA
  13. Roadster637
    Roadster637 Member
    Really interested in the "push to start" upgrade if anyone has details or can point me in the right direction.
  14. hanknum
    hanknum Member
    Santa Barbara
    Here's mine with the following mods...
    - Lotus Exige hard top with roof scoop
    - 17x8 rear wheel with 245/40-17 tire and custom center caps
    - Rear wheels on front with 205/40-17 tires and custom center caps
    - 8mm spacer on front with longer lug bolts
    - Rear brake rotors on front
    - Painted front brake caliper
    - Carbotech AX6 pads all around
    - Soundstream single DIN headunit with DVD player
    - Plasti-dip front (rear) wheels, soon to be painted gloss black to match rears.
    - Adjusted license plate P3290006.JPG P3290007.JPG P3290009.JPG P3290010.JPG
  15. drewski
    drewski Supporting Member
    SF Bay Area
  16. CAR3NUT
    CAR3NUT Supporting Member
    Tucson, AZ
    ditto for me ;)
