Several Model S/X from August 2017 to March 2018 had MCU1 and Autopilot 2.5, which uses RCCB color filter array cameras. So we know for sure that MCU1 can handle the autopilotCameraType 2 parameter. Your issue must be something else. Fortunately you were able to make everything work again by reverting the setting; specially since you don't need to change anything for all the systems to work just fine.
Are you guys ready to rock the most gigantic chrome-deleted nearly winglet style design side repeater cameras EVER!!!!!! Higher resolution images: Picture 1 and Picture 2 Source: Teslarati.
Hi, I just got my MCU2 upgraded but cannot use the same method to change the gateway settings. Just wondering how did you make the change in MCU2? Does it require root access or any softwares? Thanks!
Yes, different method. My advice would be to read around other sites and you'll eventually get there...
