As AWD and P use the same motors, inverters etc. (only differences are lot sorting and testing) are there technical limitations to Tesla offering a paid upgrade to Performance after delivery?
Yes. To be precise, the P and AWD inverters are probably the same part number, except that the P inverters are the best of the best from a given lot of parts.They use the same Motors, but not the same inverters exactly. Silicon carbide inverter on performance model are hand picked, longer burnin . I'm sure after thousands of hours of reliability testing they may allow an uncorking like they did on the S75D for normal AWD
AWD does not use silicon carbide inverter, why would they use more expensive part for regular AWD?AC induction front & switched reluctance, partial permanent magnet rear. Silicon Carbide inverters in both. Performance drive units are lot sorted for highest sigma output & get double the burn-in.
I think they would use the same part to avoid even more expense due to: 1) Switching costs on the production line to install a different part, 2) Cost to manage another part in the supply chain, 3) Cost to support another part in the finished product. Did you have a different read on Elon’s tweet?AWD does not use silicon carbide inverter, why would they use more expensive part for regular AWD?
Elon, I suppose this will be answered one way or another eventually, but many in the Tesla community are curious of what the physical setup of Performance in particular is, i.e. is it one smaller PM motor & one larger PM, or a large induction motor in the rear and a PM in front?
They can't really make the S faster from 0-60 though. They're pretty much at the traction limit unless they start shipping it with drag racing tires. I would like to see a manufacturer try some sort of active downforce like a fan to suck the car towards the ground...
So you think they might unlock more performance later?
Why does the performance need a special inverter? That's the real question. It makes no sense that it would need one if it is just 50% more powerful. All you need to do is just add a motor in the front and use the same rear motor and controller.There's already existing inverter for the RWD, Tesla can just use that? Why does a regular AWD need Silicon Carbide inverter?
This is true but CPUs have nanometer feature size. Is there really much variation in power transistors? I doubt it.Binning and silicon lottery is a real feature. Best example is AMD CPUs.
Not according to Elon Musk and the engineering team thus why they are using Silicon Carbide inverter for the Performance Model 3? or are you doubting Tesla design team's decision?
I already quoted Elon's tweet couple posts above, he was answering question on the performance not AWDBoth the AWD and Performance models have the same inverters and motors per Elon's tweet.
What if all the motors are really good from prosucprod and there is no real variation between the AWD and the performance motors?
I don’t know. Maybe the current demand of the additional motor exceeds the capability of the “regular” inverter.There's already existing inverter for the RWD, Tesla can just use that? Why does a regular AWD need Silicon Carbide inverter?
I don't see how this tweet infer to regular AWDThat's not how I read his tweet. He said the drive units are hand picked for highest sigma for the performance version.
Drive unit to me is both the motor and inverter.
Someone needs to ask him again to clarify because I thing the consensus is that both the AWD and Performance have the same units
For the Performance, not AWD.
Elon Musk said:AC induction front & switched reluctance, partial permanent magnet rear. Silicon Carbide inverters in both. Performance drive units are lot sorted for highest sigma output & get double the burn-in.
Not exactly. I think all Model 3s have silicon carbide inverters. They're the most efficient power transistors. I'm questioning whether the rear drive unit actually has more power in the performance Model 3.Not according to Elon Musk and the engineering team thus why they are using Silicon Carbide inverter for the Performance Model 3? or are you doubting Tesla design team's decision?
I think you are probably correct but the sorting could be of LR Model 3 drive units. That's what they did for the S, they added a smaller motor up front and kept the larger rear motor of the RWD version. Then for regular D they used the new smaller motor in the back as well.The AWD and Performance use the same drive unit (which is motor and inverter)
If they didn't his second sentence wouldn't make any sense at all.
What would they be "sorting" if the actual unit wasn't the same part as the AWD?
