eprosenx
If so then definitely just go to the 90-100amp circuit it will be $45 more in materials and then you are future proof. People stress over the cost of the materials but as I detailed it isn't that bad.
He can go to a max of 4 AWG in his existing 3/4 EMT so a max of an 80 amp breaker. Otherwise the entire conduit needs replaced.
Sorry about the confusion over the 20amps breaker, it was on an earlier post on page 1 (re-attached here, before and after new breaker at the top), since my panel was almost full to fit in a 50 amps breaker there was one slot left, so they did install a quad breaker with 50 in the middle and 20 on the outside.
So I'm thinking when I get the panel upgrade to 225amps I ask them to put the 20amps circuit on it's own breaker again, and then either install a dedicated 50 or 60 amps breaker.
Based on your great info guys, I'm thinking of these 3 plans right now (in the order I would prefer):
A. During panel upgrade, install 60 amps breaker and upgrade cabling to 6 AWG. It won't be as per code but again the UMC is only pulling 32 amps, so temporary solution. When the signature HPWC does arrive, remove NEMA 14-50 outlet and hardwire the HPWC. (48amps charging)
B. Don't change the wiring or breaker, remove the outlet and hardwire the HPWC. (40amps charging)
C. Keep the outlet and install the HPWC via a pigtail. (40amps charging)
D. Install the HPWC on the other side of the garage (right behind panel) on it's own 60amps circuit and get 2 charging stations, but it would be on the "wrong" side for where I park the car.
Btw to put to rest the "daily driving" / "no need to charge faster" I work in sales and can drive any time 200-300 mi to LA and down to SD and drive again at night. But yeah superchargers are there I get it, but it's more like if I can charge to 48 amps for a few more bucks why not? It's like panel upgrade, future proofing and all.
I see three options for you if you want to keep the current charge location (Option D is otherwise always an option):
1. Keep the existing wire in your conduit. Extend it to the Wall Connector. Keep it on a 50a breaker when you get the new panel. So 40a max charge (up from 32 today).
2. Upgrade your wire to #6 awg on a 60a breaker and just run the new wire direct into the Wall Connector. This gives you a 48a max charge rate which maxes out the M3.
3. Upgrade your wire to #4 awg on a 80a breaker and just run the new wire direct into the Wall Connector. This gives you a 64a max charge rate, though the M3 will never use more than 48a. This gives you a little future proofing if you think you might get a different Tesla or other EV later which could take the full 64a (Model S and X units can take up to 72a when properly configured).
Note that switching to a 60a breaker before you move from the receptacle to the Wall Connector is certainly not to code, though I have seen much worse things done. FWIW, swapping the breaker after the fact in a brand new panel would not be a very big deal.
I will call out that I don't believe putting a pigtail on the Wall Connector is a code compliant installation, though it appears to be somewhat popular. I believe it violates two things: 1. You are not following the instructions that come with the Wall Connector (this is not how they tell you to install it), 2. NEC says pigtails (where allowed) must be 12" or less. Now from a practical standpoint, it is probably fine. In your situation, I do see the benefit of the pigtail since it would require no modification, and it would give you a backup in case the Wall Connector fried you could go back to your UMC.
You mentioned in a previous post buying Red, Black, and Green #6 awg. The green (ground) can be #10 if you do a 60a circuit, but anything above that (up to 100a) needs to be #8awg ground.
Given what you have explained about your mounting setup, there is a high likelihood that I would just run conduit out the bottom of your existing electrical junction box, down, over, and up into the bottom of the HPWC. I personally would do it with EMT because I have a bender and I think it looks clean, but most would do it with Flex conduit. You can use LFMC if you prefer the looks (just get the right fittings).
Let us know what you end up with!
P.S. I am in the camp of "install the biggest thing you can". The capital costs are so low when amortized over the lifespan of a house... The wire you install may be in use 30 years from now several vehicles later (hard to say for sure). I love that my M3 charges in a little over an hour every day when I get home from work. It is always ready and waiting for me if I want to go somewhere a long way away in an emergency!
