I have an early 2016 P90DL that has only the single 40 charger onboard.
I want to either ADD a secondary charger for the "dual charger" to charge at 80A from HPWC. OR upgrade to the single 72A charger... are either of these possible?
If I go the dual charger route, do I need to buy a matched/ paired set or can I have a seperate programmed to be "master/ slave"??
The service center said they "dont program or change the car from its original configuration" who can do this? how much would this cost? do I buy the charger/s from you?
sory for all the questions after much searching, I cant seem to get a definate answer.
thank you!
thank you!
