Not to be repetitive, but I can confirm all of these models work without any changes or calls to Tesla. 5S700, 5S1500, 3S550. They are a bit pricey but you don't really need any of the normal UPS features since the Powerwall itself is what is your real battery backup.
I think maybe you missed the context of my comment with a previous one (#8 on this thread).
My point was not that they don't work at higher frequency, each of those models are "tolerant" of the 65hz frequency. The problem is that since the lower grade models are not "online" they simply pass the 65hz AC to whatever is plugged in, which in the case of a computer power supply exceeds the spec and can cause damage. You should avoid this approach and rather get Tesla to lower your frequency rather than swapping the UPS for a more tolerant one.
One thing I think people keep forgetting is that even though the Eaton UPSs are tolerant of frequency changes all the way up to 70hz your computer's power supply is likely not. The Intel ATX standard and subsequent power supply design guidelines state that the maximum input frequency is 63hz: Power Supply Design Guide for Desktop Platform Form Factors (intel.com) (page 14). Exceeding that limit could cause all sorts of problems, from crashes all the way up to equipment damage. Of course some PSUs may have higher tolerances but that will vary by manufacturer and model.
Your best approach by far is to get Tesla to reduce the maximum frequency of your system below 63hz with 62hz being a good value. Getting a UPS that is tolerant of high frequencies is a band aid and not a very good one.
