I have a 2017 MS 90D that came with the stock 19" wheels/tires. I have been changing them every season between winters and summers (in NY) without any issues.
This spring I decided to get a second set of wheels / tires to make the process easier every season and went with some recommended staggered wheels from tirerack - they are Axis MS TI Gunmetal wheels:
Front: 21x9 w/ 40mm offset
Rear: 21x10 w/ 40mm offset
Fitted out with Pilot Super Sport 245/35ZR21 on the front and 265/35ZR21s on the rear.
My installer says that the tires are rubbing (he only got as far as the first rear tire). Has anyone else had issues with fitting larger tires/wheels on the Model S? As far as I can tell these are the stock OEM 21" sizes so I'm surprised it wouldn't work.
I thought I'd ask before I returned the wheel/tire set - maybe there is some sort of spacers or other item that I should have bought to allow for the larger diameter? Thanks for any insights!
Links if they're helpful:
Rear Wheel:
21x10 Titanium Gunmetal Axis MS
Rear Tire:
265/35ZR21 Michelin Pilot Super Sport TO Tesla, Acoustic Tech
Rear Wheel:
Rear Tire:
