Urban superchargers and limit on DC charging
Brian0x32e
New Member
Oct 27, 2019
4
0
I have seen some threads and videos on YouTube about supercharging speeds being limited if you supercharge too much (above some defined amount of kWH).
Does this limit apply to the slower urban superchargers or just the 150kW+ full speed superchargers?
David99
4,850
7,021
Brea, Orange County
Yes this was first discovered with the 90 batteries. They suddenly dropped to 90 kW charge speed. It is now confirmed the 100 batteries also are reduced (to aprox 100kW) after about 25,000 kWh of DC charging. So in both cases you don't see any change at an urban supercharger as it maxes out under those limits.
The older 85/60/70 batteries are reduced as well but more by general age. They don't get a sudden limit. For those batteries the entire charge session is reduced. How much depends on the age and use of the battery. My battery for example is 6 years old and has 267 k miles. Supercharge speed is about half of what it used to be.
mjptech
Being cyberbullied by TMC users PhilDavid + DCEV
Mar 30, 2019
468
169
Ventura
25k kWh of Supercharging should be right around 50k miles for me. Is that accurate?
I've surpassed the 2500 kWh of Supercharging (new X got in July, currently just over 5k miles, and only exclusively use the superchargers).
David99
4,850
7,021
Brea, Orange County
I don't remember exactly. He did some interpolation to calculate the numbers so it might be a little off. I don;t know for sure what the limit on the 90 batteries before it gets limited. And as mentioned the older batteries don't have a threshold for a sudden reduction, they are reduced gradually. But all cars eventually get charge limited after using superchargers for a while. We haven't seen it in the Model 3 yet but remember it took years to notice it on the Model S/X cars. Very few people keep exact tarck of charge speed and compare it over time of their ownership. We also didn't have CAN bus data from the Model 3 for the first year or so before it was decoded and tools were supporting it. I'm certain the Model 3 will get a similar reduction eventually. The cell chemistry is the same as in the 100 battery packs.
Frans928
5
6
Apeldoorn
Recently I had a battery change by Tesla, so expected this number 25000 kWh and/or aging to have a reset. Unfortunately not the case!
I find Tesla should be able to reset. Does anybody know?
AAARSINIC
229
141
Carlsbad, CA
I thought I read somewhere else on this forum that the charge rate nerf had been removed in the recent software update 2020.48.35.5. Are you on this version?
VikH
941
770
Midwest, USA
For 100 packs, this was 15,00kWh before. Did Tesla bump this up to 25,00kwh?
