Hi,
I noticed around a month or so ago whilst supercharging to 100% that, once I reached 100%, it continued to charge for over 20 mins. I had places to go so stopped it manually and moved on. Recently, I thought I would retry this to see if it happened again so I supercharged to 100% and then, sure enough - it continued to charge for another 29 minutes before it eventually stopped. (Teslafi recorded charging stats showing this attached.)
Note, this is not a %age energy vs range display thing - I toggled between the two display options several times whilst this was happening - the range hit 295 miles at 100% and didn't rise any further despite the battery continuing to charge.
The fun part is that this did appear to result in more usable capacity - see my attached trip usage for the first 4 miles after leaving the charger - it stayed at 100% and teslafi stats also show the range staying at 295 for the first 10 minutes of the drive.
My take away is that I appear to have a few percent capacity above "100%" which I can both charge up and run down by using the car.
Has anyone else seen this or, even better, know how I might trigger a recalibration to realign display "100%" with the real 100% ?
Thanks
Thanks
