Haven’t read thread from beginning and still haven’t tried out our Model 3 dashcam (that’s one reason I’m reading the thread), but from a few pages I’ve read people are saying they have partitioned the drive for dashcam and video, which the manual says not to do.
I've had zero problems since switching from a garbage Microcenter branded USB drive (which was handy and unused at the time, but has awful performance) to a fast but not expensive Samsung USB drive (it was about $12 or so). Have you tried a faster and/or "higher end" drive? One of the theories is that corruption happens because the drive doesn't finish writing the last write before losing power when the car shuts down.My cam works for a few days and then fails. When I mount the flash drive in Windows it says it's corrupted. After fixing the partition, there's not much left, and the files that are left are sometimes corrupted. There are some commercial drive reconstruction utilities out there that will find the files and copy them. Do that rather than letting Windows fix the drive.
It's a total mess and Tesla needs to fix it.
Some quick googling seems to indicate there's no way to do the dual partition format on a Chromebook (at least on stock Chrome OS), but if you want to just format it as FAT32 for just dashcam use (not two partitions for dashcam and music), then it looks pretty simple (assuming nothing has changed too much in 4 years ... ) : How To Format an SD Card or USB Drive on a Chromebook - OMG! Chrome!Can anyone tell me how to format my USB on a chromebook?
If you wish to create two partitions instead of just using the one already there, your Chromebook has to be in developer mode to get access to the command line tools. Enabling developer mode requires a powerwash/reset that deletes all locally stored downloads, so it's probably not worth the effort unless you can't borrow another computer to partition the device.Can anyone tell me how to format my USB on a chromebook?
Can you create any directories / files in the top level of the USB stick? If not, it's possible the entire device has gone read only due to write wearout though that seems unlikely unless it was either a garbage device to begin with or an older USB drive you've had around for a while. A new device should last for months at least, even if it's a smaller storage or budget device.I'm experiencing the same or similar issue: An issue seems to be that the \TeslaCam directory has become "read-only," that I can't undo with DOS commands.!!! With a new datastick, problem went away. But browsing SanDisk seems to reveal a similar thread. If I put into the car a DataStick with the TeslaCam directory marked "Read only", I get a camera icon with an X. With the original (and now, new) data stick, (not read-only), the camera icon has a red dot and is (presumably) recording.
Research is needed into what "turns" the TeslaCam directory to Read Only, and why we can't undo the status.
Googling the DataStick Read-only directory issue show that other folks have that problem as well.
For me several newly formatted drives worked fine until drives were full, then quit recording. Exchanged several emails with Tesla support and issue seems to lie in software not overwriting oldest recordings so as to only store last few minutes of car’s operation.My advice: Forget about it until Tesla fixes the software. The dashcam doesn't work in the present version beyond a brief time after a newly formatted drive is inserted. I imagine Tesla knows this by now and it's in the queue for revision.
Try a different usb drive. Some of them are just too cheap and cant handle the constant writing of the files from the camera.Anything new here? I'm on 50.6 and still getting corrupted USB drive. I repair, but corruption still happens.
My drive gets corrupted if I remove it without pausing the recording.
I have to pause the recording, and then remove the drive.
I do wonder why I need a recording of inside my garage when I'm just sitting in my car in park.
Confused, wouldn't those videos just be part of TeslaCam's buffer (RecentClips) and not saved as MPEG-4s inside of the SavedClips folders? No reason to have Sentry Mode on if the car is parked inside the garage. Disable as you get out of the car when parking in the garage or disable from your app remotely. Sentry Mode would be the only way I can see video files automatically getting saved.
Tesla's manual says not to remove the USB flashdrive until you have paused the recording or the files will be corrupted.
