USB Dashcam not starting automatically at beginning of drive - 2019.12.1.2
Discussion in 'Model 3' started by eyespii, May 13, 2019.
  1. eyespii
    eyespii Member
    Orange County, CA
    Anyone have an issue where the dash cam won't automatically start recording at the beginning of their drives sometimes? The recording icon sometimes doesn't show up until I unplug/replug the USB drive. I just did a reformat of the drive to see if it would fix it, but no luck - maybe mine is bad?
    I'm using a 128gb sandisk ixpand for what it's worth.
    Thanks!
  2. slowdriver
    slowdriver Member
    yes it started happening my M3 last week... I was using a USB hub. I removed the USB hub and connected the SSD directly to one of the Front USB ports, and now the TeslaCam icon shows up and starts to record automatically when I start the car.
  3. eyespii
    eyespii Member
    Orange County, CA
    Hmm, I do have the usb drive connected via an usb-splitter, so maybe that's causing the problem?
  4. slowdriver
    slowdriver Member
    possible. Try connecting the HD directly to the car's USB Port
  5. Eric D. Mann
    Eric D. Mann Member
    Los Angeles
    Thanks for this info. It’s happening to me with same set up. Will now plug in directly.
  6. Eric D. Mann
    Eric D. Mann Member
    Los Angeles
    Also. It said it was recording (red light on) but wasn’t...
  7. eyespii
    eyespii Member
    Orange County, CA
    So Seems like every time I plug the usb drive in directly to the port, it starts up fine and works. But, now my wireless charging pad (nomad gen 1) won’t work, cause both USB ports need to be plugged in.
    Anyone have a workaround? Maybe I need a different splitter? Im using this onvian usb splitter here
    Onvian USB Splitter Cable Male to 2 Female Adapter USB A Cord 2 Port Hub for Data Charging Syncing (Only one Port for Data) https://www.amazon.com/dp/B01KX4TKH6/ref=cm_sw_r_cp_api_i_4kC6CbGFKX07V
    Still on 2019.12.1.2 also.
