USB Drive FAILURE
Discussion in 'Model Y: User Interface' started by theganjaguru, Dec 31, 2020.
Which USB Drive Do You Use - Drive Failed
  1. Scandisk Ultra Fit USB 3.1 - No Failure
    0 vote(s)
    0.0%
  2. Scandisk Ultra Fit USB 3.1 - Drive Failed
    1 vote(s)
    20.0%
  3. Samsung MUF-64AB/AM FIT Plus – 200MB/s USB 3.1 Flash Drive - Drive Failed
    0 vote(s)
    0.0%
  4. Samsung MUF-64AB/AM FIT Plus – 200MB/s USB 3.1 Flash Drive - No Failure
    0 vote(s)
    0.0%
  5. Another Brand High Speed USB 2.0 Compatible Drive - Drive Failed
    0 vote(s)
    0.0%
  6. Another Brand High Speed USB 2.0 Compatible Drive - No Failure.
    4 vote(s)
    80.0%
  1. jcanoe
    jcanoe Active Member
    Maryland
    Is there a light inside the lower center compartment? I ask because on the original console there is a light that comes on inside the console when the cover is flipped up.
  2. eladts
    eladts Member
    Brookline, MA
    That's not accurate. As far as I understand, newer Model 3/Y have the following USB ports:
    • USB-A inside the glove box (data at USB 3.0 speeds)
    • 2 USB-C inside the rear of the center storage compartment (data at USB 2.0 speeds + PD charging)
    • 2 USB-C below the rear vents (PD charging only, no data)
  3. jcanoe
    Maryland
    I do believe you are right. Has the Owner's Manual been updated?
  4. Blucenturion
    Blucenturion Member
    Humboldt Co., CA
    And so it is. That's accurate.
