steph280
I wonder how these would fair in high temperature environment inside the car during summer? I've had a few older USB memory sticks fail in my previous car already, which I suspect is due to heat.
Info at Amazon indicates the stick operates at up to 113 degrees F, but can be stored at up to 158.Any decent USB flash memory should be able to withstand significant temperature tolerances as there are no moving parts:
http://kb.sandisk.com/app/answers/d...erance-(waterproof,-temperature,-magnetic-and
"SanDisk SD, SDHC, microSD and microSDHC memory cards are capable of withstanding operating temperatures from -13ºF to 185ºF (-25ºC to 85 ºC)." -- This is back in 2009 so the tolerances might be even better now.
Stop using USB sticks, get an SSD instead. Faster scanning and way more reliable since you'll mainly be reading from it.
Guys, for those who ordered the drive, can you tell me what the File System by default is on it?
I formatted mine for some other stuff I needed and now I'm stuck with either NTFS and exFAT. I've found a workaround solution with FAT32Format application, but want to format it to it's default, so it can be read easily.
Yes you can. I have a 256GB stick that is fully accessible. It was formatted on my Mac with nothing special. No fuss, no muss.Guys, can you format a FAT32 drive beyond 32 Gig? What will Tesla system read?
JWood
JWood
Costco has 128 gig on sale to the end of the month for $25. I picked one up and tested it out, works fine no need to re format.around $30 is the current price for a 128G USB. Nothing special, Frys, newegg has them, I saw COSTCO has them . I wouldn't worry if you miss this deal that isn't really a deal
128GB low profile flash drive. Amazon.com: SanDisk Ultra Fit 128GB USB 3.0 Flash Drive (SDCZ43-128G-G46): Computers Accessories
Correct me if I'm wrong: USB sticks are SSD.Stop using USB sticks, get an SSD instead. Faster scanning and way more reliable since you'll mainly be reading from it.
