USB port management if the Dashcam update in Rev 9 takes 1 port
Discussion in 'Model 3: User Interface' started by rvandrew, Sep 27, 2018.
  1. rvandrew
    rvandrew Member
    Utah
    I know in the "interior and exterior" area of the forum there was a lot of talk about the possibility of adding a hub, but as far as I can tell, the majority of the users were looking at hub management for phone charging purposes. This seemed more of a connectivity issue. Now that there is talk of needing a USB thumb drive for Dashcam data, is there a spot on the forum for the possibility of adding a USB hub for data management? I know there are those who use an existing USB port for music on a thumb drive. One of the proposed solutions to the multi-hub question was this
    https://www.amazon.com/gp/product/B071JTSMVQ/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1&tag=eatirule-20&tag=tmc064-20
    or
    https://www.amazon.com/Cute-USB-2-Port-Splitter-Black/dp/B00FJG5T4W/ref=sr_1_4?ie=UTF8&qid=1515280980&sr=8-4&keywords=small+usb+hub
    they are a bit clunky, but perhaps functional enough. Do these mini-hubs work? Do you think a person could plug in a "music" thumb drive as well as a "dashcam" thumb drive in one?
    As far as I know, there are only 2 of the ports that are "data" ports as well as charging. Naturally these are also in the most convenient spot for pluging in a phone charger. So, how are people planning on juggling the new need to tie up a USB port?
  2. HankLloydRight
    HankLloydRight No Roads
    Connecticut
    You can most likely use the same USB drive for music and the dash cam as long as it has the “Teslacam” folder (or is it “Tescam"?) for the dashcam video clips.
    • Disagree x 4
  3. LonestarV
    LonestarV Member
    TX
    Unfortuately, no. From the manual:
    Note: When connected, the flash drive is dedicated to dashcam only. It cannot also be used to play media files.
  4. HankLloydRight
    Connecticut
    Ah, ok. I only saw the on-screen release notes that mentioned the Tescam folder. There was no mention of a dedicated drive.
  5. TT97
    TT97 Active Member
    Los Angeles
    Where did you get the manual with Ver. 9 info?
  6. LonestarV
    LonestarV Member
    TX
  7. J1mbo
    J1mbo Active Member
    UK
    If you have AP2.5 in your car (required for Dashcam) then you should also have 2 extra USB ports facing the rear seat...
    • Disagree x 1
  8. apacheguy
    apacheguy S Sig #255
    So Cal
    These are only used for phone charging for the rear seat passengers. They are not wired into the infotainment system.
  9. rvandrew
    rvandrew Member
    Utah
    So, there are 2 usb ports in the front, (data and power) and 2 USB ports in the back. (Power only. ) Has anyone tried putting any kind of hub onto the front USB ports in the front to see if the system can recognize multiple thumb drives off of one "port"?
  10. LonestarV
    LonestarV Member
    TX
    And technically they are present due to having the Premium Interior rather than AP 2.5.
  11. rvandrew
    rvandrew Member
    Utah
    So, is it possible to put two USB drives connected to a hub connected to one port and have the car see both thumb drives? I would try it myself, but my car is in having clearbra put on.
  12. rvandrew
    rvandrew Member
    Utah
    Because if that is possible, it may also be possible to put one drive with music, and one drive configured to be a dashcam drive both attached to one port, leaving the other port for phone charging and other fun needs.
  13. lairdb
    lairdb Member
    I have not tried multiple drives, but I can confirm that an old hub works and allows one drive and (slow, bus power) charging of a phone.
  14. lairdb
    lairdb Member
    The ever-handy Jon Osborne posted a video in which he took the console apart and tapped the lighter to put a second lighter outlet on the same bulkhead as the USBs. Until and unless Tesla does something interesting with the phone data connection, I'm thinking of doing that and using a two-output USB lighter for the power to the phones (or one to the less-used side), leaving the stock USB outlets for drives.
    Screengrab:
    • Informative x 6
  15. LonestarV
    LonestarV Member
    TX
    I'm going to wire my Aukey 12-volt to USB up to the front cell phone dock area using the method RPM Tesla did for their wireless install (once my angled micro-usb cable arrives this weekend). Will make it easy to convert that to wireless Qi fast charging in the future once I settle on something.
    • Informative x 2
  16. J1mbo
    J1mbo Active Member
    UK
    Technically they are present due to having the Premium Interior post Aug 2016. But cars built between Aug 16 and end-July 2017 can't use Dashcam so... *shrug*
  17. Rogue one
    Rogue one Member
    Wisconsin
    That is what I’m doing, I’ll get faster wireless charging because the front ports are painfully slow.
  18. evpulse
    evpulse Member
    San Diego
    I think this is the best option currently. I plan to do something like this for my Nomad when it finally arrives, which will give me a backup front USB port for non wireless devices and 1 dedicated for the dash cam storage.
  19. wbhokie
    wbhokie Member
    Woodbridge, VA
    Does anyone know of a cigarette lighter / USB splitter that will fit in the 3 that will not interfere with the tray? I want to be able to do what that video shows with the USB but also still be able to have the cigarette lighter port. There are plenty of USB only adapters that will fit but I'm not sure if any combo adapters fit.
    Something like this : Will this fit or is the plug too big for the tray?
    https://www.amazon.com/Splitter-Te-Rich-Cigarette-Lighter-Extender/dp/B07919SSGH/ref=lp_13672506011_1_2?srs=13672506011&ie=UTF8&qid=1538282199&sr=8-2
  20. insaneoctane
    insaneoctane Active Member
    Southern California
    That's the one that I use... Fits great.
    Also I have this hub with 2 thumb drives and they both play fine.
