USB Rechargeable Batteries
Discussion in 'Energy, Environment, and Policy' started by ggies07, Dec 4, 2013.
  1. ggies07
    ggies07 Supporting Member
    Ft. Worth, TX
  2. tom66
    tom66 Member
    United Kingdom
    Neat. But the charging circuit is a resistor and diode, which means the battery won't last if left continuously to charge. The capacity is also rather limited (1300mAh; typically AA NiMH achieve 2000~2500mAh.) I just use a twin-AA smart NiMH charger (USB powered), plus you're not stuck with buying a specific battery when one of the NiMH die.
  3. Raffy.Roma
    Raffy.Roma Active Member
    Rome (Italy)
