USB to iPhone 5 Charger Flexible Yet Rigid - SOLD
Phil Gorski
408
9
Vancouver
Work great in a TESLA MODEL S - as pictured.
Also works great in other vehicles outfitted with a USB port as well as a laptop.
Charging/Sync Cable Is Flexible yet Rigid - approximate length is 7 1/2 inches
It's a charging/sync cable equipped with a USB connector on one side and a Lightning connector on the other, and it's rigid enough to hold your iPhone 5 or iPod in whatever position you desire.
2 versions available
- USB to iPhone 5 - Lightning adaptor
- USB to Micro USB adaptor
Sometimes you need your phone placed in a certain position a task that can usually be accommodated with your hands but not while you're driving.
Check out the photos that shows how your Phone can be positioned right where you need it in the car.
In addition, if you occasionally hang out at coffee shops to write, code, or surf the web, often while doing so, you almost always charge your Phone from your Laptop. Unfortunately, we often tangle the Phone cable while trying to keep it neat and out of the way of other patrons. However, this device is essentially a short cable with a reinforced housing.
The length keeps it out of the way, and the reinforced housing allows it to double as a stand without causing damage to your computer's USB port or your Phone's connector.
Email any question you may have.
List Date: 1/14/2014
For more info, click here to view the original listing: USB to iPhone 5 Charger Flexible Yet Rigid
SOLD
Gizmotoy
3,657
859
Bay Area, CA
If you bend it down, will the top of the phone rest on the carpet? I like the idea of it holding my phone in place, but not really the idea of the entire weight of the phone resting on my USB port.
Phil Gorski
408
9
Vancouver
It's designed to hold phone up for viewing. If you want to place your phone on the console carpet - I suggest a shorter iPhone cable. They do make short ones.
