rxlawdude
Here's something for you to try, if you have a USB flash drive and are getting a "too slow" message: Take the flash drive to your computer and try transferring multi-GB files to it and (with Windows) open "details" on the transfer status window. If your results are like mine, you'll see this is indeed hardware. I was shocked to see a sawtooth pattern, going from 30MB/sec to <1MB/sec with a Samsung high-end USB that was in use five months. (And the first "too slow" message occurred during V9, late in Spring.)Total nonsense.
For one- the Teslacam isn't a high-usage security camera.
It's writing 720p video as a much lower rate than the actual modern 4k high-use security dashcams are.
In normal usage (8-10 hours a day) it'd take 5-10 years to burn through the rated write-cycles on a 128GB USB key (any brand) with how little data Tesla is writing to it.
It's absolutely a software bug- because many folks with exactly the same HW are having totally different results.
Folks with SSDs, SDCards, and USB keys- even the same ones as each other- some have the issue- some don't- and even among those who have it there's a lot of variability in how it presents.
A problem that runs across all types of HW, and starts happening after a software update to previously just-fine hardware, is a software problem.
Except folks were getting "too slow" even before they added the 4th camera. In fact for some folks the problem was "fixed" with V10- for others it suddenly appears with V10... for still others it only appeared a little while after V10.
And the 4th camera only increases the write speed from 1.5 MB/s to 2 MB/s- still much slower than even the slowest sustained write speed of USB keys.
Here's a review of the Samsung BAR plus for example-
https://www.storagereview.com/node/7097
Sequential write speeds measured as 61.84MB/s- random 2MB writes as 56.01MB/s (granted this is on a USB3 bus and the car is USB2, but it shows the actual key can easily by a factor of more than 25x handle the speed the car needs.
It's a software problem.
There's a lot of things the problem could be- crap USB controller code, crap handling of the video files between computer, cache, and storage, crap error checking, etc...
What we can be sure of- given even folks with HW many many times faster than needed also have the issue (while others with measurably slower devices don't) is that it's not a HW problem.
So rather than speculate, TEST. If your computer transfers to the media run at a constant speed >20MB/sec, you should not see the message in the car.
