  • The final cut of TMC Podcast #27 is available now with topics time-stamped. We discussed: Consolidation in LiDAR manufacturers; Volvo EX90 shipping with LiDAR; FSD Beta Full Release in N.A.; FSD detecting autopilot cheats, Gwen Shotwell directly overseeing SpaceX Starship; and more. You can watch it now on YouTube. We should have it published to podcast networks shortly.
Using Apple Lightning to USB 3 adapter
USB C spec states a minimum of 3 amps and a maximum of 5 amps. I doubt the Tesla USB C connection can actually supply even the minimum 3 amps considering there is more than one in the car and the combined potential is too great. I have always felt that the older Tesla USB 2 ports in my MS are underpowered, and I suspect the Tesla USB is just an old style USB port with a USB C plug.
Power requirements not withstanding, is this transfer feature even available? Perhaps things have changed but don't you need some external USB storage device to even record sentry vids? I guess I am not clear as to what you wish to do.
I unplug the USB drive that is capturing Dashcam footage and connect it to my phone to copy the videos over. I'm just using the USB-C port in the car for power in this case.
I see, makes sense. Lots of posts about the finicky USB C ports in Teslas. From what I learned the ports do have the power to charge larger devices so I was wrong about that. The problem seems to be with specific devices and cables, mostly the cheaper knock-offs. Not sure what to suggest on this one since you are using an Apple adapter, generally considered the "Gold Standard" and certainly not cheap or or a knock-off. I use an external SATA to USB 256GB SSD drive which fits under the console. I have resigned myself to using the terrible, slow-as-hell, featureless in car viewer, and in that case the SATA SSD drives tend to be the fastest solution. If I want to transfer the files I unplug it and connect it to my Mac, but I realize that is not your goal. Good luck!
