I'm looking to swap my front springs (2018 LR RWD) with parts from a SR+ or similar. I've located a set from a 2022 RWD car, but I'm unsure if they're compatible with the earlier cars.
Reason? It appears Tesla may have used the AWD springs on the LR RWD, resulting in overly stiff/harsh front suspension. The rear suspension seems closer to perfect. If I can run softer springs I can increase tire pressure and improve range. I've read a lot of comparison posts and everyone says their AWD or P car is much smoother than the LR AWD.
Does anyone have a breakdown on the part numbers, compatibility or any additional info? I was looking to get the mild dual rate lowering springs, but there's too many complaints of noise from the coils binding and moving around in the spring seats. OEM always works.
Thanks!
Thanks!
