Using Homebridge and Siri to control your Tesla
Discussion in 'Model S: User Interface' started by wayner, Jan 18, 2016.
  1. wayner
    wayner Active Member
    Toronto
    Has anyone tried this yet. Homebridge is available on Github at https://github.com/nfarina/homebridge. There are 88 plugins available here https://www.npmjs.com/search?q=homebridge-plugin
    You run it on something like an RPi and it acts as a bridge between iOS' HomeKit.
    I am no expert on this but it should be very doable to whip up a plugin to use voice commands via Siri to start and stop charging, turn on climate, unlock, etc.
    Here is the description from Github:
  2. SteveW25561
    SteveW25561 Member
    Vancouver, Canada
    This wold be soo great especially if there's some way to do it remotely (not on your own network). I suspect this won't do it but even home voice command would be useful. Subscribing in hopes someone will figure out how and post the tutorial.
  3. joaquinsfy
    joaquinsfy Member
    barcelona (spain)
    I just started to work with HomeBridge this morning, i setup the Bridge and also a WeMo Switch, i see there's a Tesla plugin, (i have a p85+), and i think it's easy to use it, but i think that you need to be in the same network (wifi), i will take a deep look ...
  4. wayner
    Toronto
    Can you provide a link to the Tesla plugin? I didn't see that.
  5. joaquinsfy
    joaquinsfy Member
    barcelona (spain)
  6. wayner
    Toronto
    It looks like that uses teslams which is also written in JavaScript and allows full control of the Tesla. But I don't know the significance of the term "legacy-plugins". I think Homebridge has only been around for a few months so it shouldn't be an issue that it has been deprecated.
    edit - Here is what it says about legacy lugins:
  7. joaquinsfy
    joaquinsfy Member
    barcelona (spain)
    Wayner, the problem with HomeKit is , that HomeKit is to commands devices, so, no answer come's for the device, i mean, you can send commands like "open the door" "start the car", but you can not ask "which is the level of the battery..", "is charging?", this kind of commands doesn't work with HomeKit, Amazon Echo can do it.
    Tesla + Amazon Echo on Vimeo
  8. msnow
    msnow Active Member
    SoCal
    I don't see the point in spending $179 + tax for something that can only do what the API allows it to do.
  9. rfmurphy81
    rfmurphy81 Member
    Orange County, CA
    How do you set this up?!?! :)
  10. wayner
    Toronto
    Well that's not ideal but I am willing to try it. I carry an iPhone with me but I don't need an Amazon Echo in my house, at least not yet.
  11. gerti
    gerti Member
    Minnetonka, MN
    HomeKit supports status messages (like ambient light level etc) just fine.
  12. joaquinsfy
    joaquinsfy Member
    barcelona (spain)
    Wayner
    More info: in the folder /usr/local/lib/node_modules/homebridge-legacy-plugins/accessories/Tesla.js (in a Mac) you have the javascript File, in these Javascript use the Teslams calls.
    in your config.json (Homebridge you need to put your password and email for the Teslamotors account"
    "accessory": "Tesla",
    "name": "Tesla",
    "description": "This shim supports controlling climate control on the Tesla Model S.",
    "username": "-------",
    "password" : xxxx"
    and that's it, now you can start-stop the climate with Siri, works. But only these function is used in Tesla.js, you can add more if you want.
  13. msnow
    msnow Active Member
    SoCal
    Just so I understand, this plug in installs on your computer or iOS?
  14. joaquinsfy
    joaquinsfy Member
    barcelona (spain)
    The plugin is installed in your computer (the computer is the bridge)
    in iOS you just have a Database with you compatible HomeKit devices (defined in the bridge).
    Now i can control using SIRI the climate (just start - stop) and get the % soc from my tesla.....
    Note: to add the "Bridge" to ios Homekit you can use the app named "eve" from elgato, this apps has the ability to add the HomeBridge to you iOs database using the id " 031-45-154"
  15. mbhforum
    mbhforum Active Member
    Long Island, NY
    Has anyone gotten this to work reliability?. When I try this, I get "the requested accessory Tesla was not registered by any plugin". I installed homebridge-tesla and teslams, but it didn't seem to make a difference. I am using a Docker image of homebridge running on my Synology NAS.
  16. ronm2948
    ronm2948 Member
    Oregon
    You could also try the “Remote S” app which allows you to create Siri shortcuts to control your Tesla. I believe that all of these shortcuts would be available to use on your watch as well. I can’t vouch for how well they work, but there is a video showing someone building the shortcuts:
    Available shortcuts are:
    Siri Shortcuts supported:
    - Unlock/lock car
    - Start/Stop HVAC
    - Roof/Trunk/Frunk control
    - Temperature change
    - Max Cool/Heat
    - Honk horn
    - Flash lights
    - Summon reverse/forward/stop
    - Trigger HomeLink
    - Start and stop charging
    - Open/close charge port
    - Change charge limit
    - Switch cars
    - Display charging stats (battery left, time left, range left, etc.)
  17. mbhforum
    Long Island, NY
    Yes, I’ve been playing with that too, and have found the behavior inconsistent so far. I’d rather avoid using shortcuts as direct HomeKit devices seems to be faster. Check out the error I get from my watch. Works on my phone though...
