Using Model S to jump another vehicle
Discussion in 'Model S: Battery & Charging' started by yobigd20, Jun 18, 2014.
  1. yobigd20
    yobigd20 Well-Known Member
    Skaneateles, NY
    I'm just curious if anyone has attempted jumping another vehicle using their Model S.
    I kinda thought it would be ok so I jumped my lawnmower which always has a dead battery every week (I'm lazy and it really needs a new battery). Usually I jump it from my wife's car but she was out.
    I didn't know if the Model S should be on in any way shape or form. I just popped out the nose cone and hooked it up and jumped. But I didn't have any problem. It jumped right away. In fact, I'd say it jumped much quicker than any other week that I jumped it with my wife's ford flex.
    Anyone else try this? At least this was for a lawnmower battery which is smaller than a car's battery. I guess what I would be afraid is draining the 12V completely on the MS and then having to jump that lol. I don't even know if that is possible to drain the 12V bc wouldn't the MS keep it fully charged from the main battery pack?
  2. FlasherZ
    Two different scenarios to consider here -
    1. Using the DC-DC converter to charge another vehicle's battery: doesn't seem like it would be too big of a deal, although Tesla calls it a no-no. The reports are that the DC-DC converter is rated ~200A/12V or so, and that should be enough to provide a reasonable charging supply to another battery. You'd probably want the main contactor closed, so having your door open and the car awake is probably the most important point here.
    2. Leaving it connected while you attempted to start the other vehicle. This is a BIG no-no, IMO! Current draws of several hundred amps from a traditional ICE starter motor could end up damaging the DC-DC converter or blowing the fuse. I suspect that if you did start the lawnmower while it was still connected to the Model S, you didn't risk too much because those motors are much smaller. Do not do this with another car!
  3. yobigd20
    Skaneateles, NY
    I'm pretty sure I had the door open. Had no idea about the converter thing though. Good to know! Is this stated in the manual anywhere?
  4. Kalud
    Kalud Active Member
    Montreal, QC
  5. Todd Burch
    Todd Burch Voltage makes me tingle.
    Smithfield, VA
    Although FlasherZ blows me away on electrical knowledge, I know enough to say that I agree with him :).
    The Model S doesn't need any massive currents from the aux battery for any reason, whereas ICE batteries are designed for large cranking currents.
    I wouldn't attempt to charge another battery with the S battery. Maybe it would be ok for a smaller battery, but if the battery has a large capacity and is at a low state of charge, it could draw a lot of current and blow a fuse. That's probably why Tesla doesn't condone it.
    Attempting to crank while connected will definitely try to draw cranking amps from the aux battery on the S, which ought to blow a fuse...you might luck out with a smaller motor, but you don't know what's big enough to blow that fuse or cause damage. I'm keeping my S battery safely tucked away.
    Go get that new battery, yobig :). It's 5 minutes at a hardware store, and they'll pay you for the old battery (just like Tesla! haha)
  6. green1
    green1 Active Member
    Calgary, Alberta, Canada
    I have successfully boosted a vehicle through a 30A fuse in the past, so I wouldn't say you can't do it with 50A, (it all depends on just how close to "enough" their battery still has) but you are right in principle, there's a high chance of blowing that fuse.
    My suggestion would be, as others have said, use it to charge, but not to start. So if your friend's car is dead, hook up cables, let it sit for a while, (5-10 mins?) and then disconnect the cables and let them try to start. You can always try again with a longer wait if it fails the first time. That said, there is still a risk to this procedure, and you will find at this point that almost all manufacturers advise against boosting another vehicle (not just Tesla), if the other vehicle just has a dead battery and no other problem, there's very little risk, however you have to wonder why the battery is dead, if there's a short, or marginal short in the wiring of that other vehicle there's a risk of blowing that 50A fuse and/or damaging your 12V system. There's also always the risks associated with reverse polarity if you aren't paying enough attention hooking things up.
  7. yobigd20
    Skaneateles, NY
    lol ok I won't do it again. It worked though haha yea I'll go get a new lawnmower battery. It's for a zero turn john Deere. That's my gas guzzler now.
  8. tga
    tga Supporting Member
    New Hampshire
    My Dad did that once jumping an ICE off another ICE. The dead car's battery cables had been replaced, and the idiot had swapped colors (so the black went pos to starter, and red neg to ground). My Dad's car was running, and he happily connect red to red and black to black. There was a bit more arcing than usual, and the his engine bogged down, but he figured it was just because the battery was really dead and drawing a lot of charge current. Then the cable melted at the clamp and popped out of the crimp! :eek: I suppose the fact that the battery was really dead may have limited the current flow somewhat.
    They figured out what had happened, got new cables, and got the other car started. Surprisingly enough, all was fine (the dead car was old enough that it probably pre-dated on-board electronics).
    - - - Updated - - -
    Avoid the Deere batteries. They have a nasty reputation for leaking around the terminals. When the one in my tractor died, I replaced it with a sealed AGM battery for a Miata (U1R, regular post terminals). No leaks, no checking water, low off-season self discharge. I got it here:
    Mazda MIATA Battery - Free Shipping: BatteryMart.com
    I had to fabricate a different clamp (threaded rod, with a bar over the top of the battery), as it didn't have the side clamps "wings" molded into the case like the original.
    If yours uses the through-bolt terminals, this one won't work. The commercial tractors use automotive posts, but I don't know what garden tractors/riding mowers use.
  9. jerry33
    Texas
    The correct answer is: Purchase a jumpstart kit.
    If it's a real emergency, you should be able to get by with the following (Note: that this is the same method used for the Prius and would presumably be the same for any car with a small 12V battery):
    1. Take the keys from the other vehicle's owner and make sure s/he doesn't have a spare set. This is vital. If they attempt to start the car while it's connected it can do severe damage to the Tesla.
    2. Pop the nosecone and locate the jumper terminals.
    3. Connect positive to positive.
    4. Connect an unpainted metal surface on the dead battery car to the negative jumper terminal on the Tesla.
    5. Have the Tesla turned fully on so that the 12V battery remains charged.
    6. Wait 15 to 30 minutes for the dead battery to charge.
    7. Remove the jumper cables in the opposite order (negative first).
    8. Give the dead battery owner back their keys and see if the other car will start.
    9. This is an emergency procedure, not a recommendation. Once told they will have to wait 30 minutes, most will find another solution.
  10. Kipernicus
    Kipernicus Model S Res#P1440
    Belmont, CA
    I came into this thread expecting Dukes of Hazzard or KITT type jumping. Not this talk about electricity. thumbs down
  11. FlasherZ
    In a Waylon Jennings voice:
    "Looks like Kipernicus has got himself twisted around, don't you think?"
  12. LMB
    LMB Member
    South Shore Boston
    (LMB spouse)
    As I described in an earlier thread about this, I did the following to start our slightly dead ICE from LMB's Tesla last winter. No nosecone popping involved.
    1) Connect cheap 6A battery charger to dead battery hot and dead vehicle frame.
    2) Connect cheap 150 watt inverter to 12 volt socket between Model S front seats.
    3) With Model S on, plug charger into inverter (note: charger too cheap to have power switch).
    4) Wait 10 minutes.
    5) Disconnect in reverse order.
    6) Start dead ICE vehicle.
    Worked a treat.
  13. tezco
    tezco Sig P85
    Colorado
    For me the correct procedure is: "I have a very hard to get to 50A fuse in the circuit that will blow if your battery draws more current. Since you can't guarantee that, we'll have to wave down a gasser with an easily accessible battery, and a 100A alternator."
